W205 Battery Current reading (IB)
Old Jun 11, 2021 | 07:58 PM
kingoo's Avatar
2020 GLC300, 2016 C300
W205 No Battery Current reading (IB), (Solved)
Hello
I have an issue with my 2016 C300, I get the error message (Start Engine See Operator’s Manual)
I took the car to an independent Service Center and they tried installing 2 new batteries (Genuine MB Batteries) but keep on getting the same error message.
And when I check (Vehicle Data) I see no (IB) reading as per the attached photo
Also, my eco start-stop function does not work at all, it does nothing when I press the button and nothing appears on the dashboard when the engine is off the button’s green light goes on and off when I press the button.
sometimes the KEYLESS-Start doesn’t work it says Key’s Not Detected, I tried changing the Key’s battery twice with no luck…
I also swapped the -ve battery terminal sensor with no changes
any ideas or fixes?
thanks a lot in advance
Old Jun 12, 2021 | 12:08 AM
MBenzOwner's Avatar
C300
Originally Posted by kingoo
Hello
And when i check (Vehicle Data) i see no (IB) reading as per the attached photo
Also my eco start stop function does not work at all, it does nothing when i press the button and nothing appears on the dashboard, when the engine is off the button’s green light goes on and off when i press the button.
any ideas or fixes?
did you check for any xentry codes? Maybe battery sensor or something with alternator? Was IB working when you had this error
message before the battery change?
They recommend unplugging the
battery sensor when changing the battery to prevent damage.
Do you have any issues besides eco start / stop. That is rightly off because the computers sees something wrong with the electrical system and it will not allow eco start stop to work. Once the underlying problem is fixed, eco start stop may work.
Old Jun 12, 2021 | 02:54 AM
kingoo's Avatar
Thank You for the quick response…
they said there were no codes
also I forgot to mention that sometimes the KEYLESS-Start doesn’t work it says Key’s Not Detected, I tried changing the Key’s battery twice with no luck…
Old Jun 12, 2021 | 09:36 AM
MBenzOwner's Avatar
C300
There’s has to be a code if you have a dashboard error message. You need enhanced Mercedes diagnostic OBD or someone with xentry software. The front SAM controls those two systems so you may need xentry access to investigate that too.
Old Jun 12, 2021 | 09:39 AM
kingoo's Avatar
Will try to check with xentry diagnostics
thank you
Old Jun 14, 2021 | 09:15 AM
kingoo's Avatar
Hello
any ideas or fixes?
Any Assistance would be much appreciated
Old Jun 14, 2021 | 09:33 AM
Cosworth2000's Avatar
2022 E53 AMG
Your auxiliary battery maybe faulty
Old Jun 14, 2021 | 10:18 AM
kingoo's Avatar
I tried to remove the aux battery and got (aux batt malfunction) error code
the code went off after reconnecting it...
so it's fine I suppose
Old Jun 14, 2021 | 01:08 PM
stockbmw's Avatar
2018 C43
You get the IB no reading when battery sensor grey clip is unclipped or is defective.
Old Jun 14, 2021 | 01:39 PM
2022 E53 AMG
Nice.. that is good news
Old Jun 14, 2021 | 02:40 PM
kingoo's Avatar
which Sensor? on the -ve or +ve terminal?
Old Jun 14, 2021 | 02:41 PM
stockbmw's Avatar
2018 C43
Battery voltage sensor grey clip is right on the neg terminal.
Old Jun 15, 2021 | 05:19 PM
kingoo's Avatar
Thanks a lot
Old Jun 16, 2021 | 05:48 PM
kingoo's Avatar
Problem Solved
After a tedious search on the internet, I found this document that helped me fix the issue
https://static.nhtsa.gov/odi/tsbs/20...34790-9999.pdf
While I was checking the wires and connector of the -ve Terminal sensor I found a disconnected red cable laying around (My guess the previous owner disconnected it to permanently disable eco start stop) and as per the above document it should be connected to the +ve terminal
I did connect it as advised and voila issue resolved and the error message has disappeared
Now I get (IB) readings and the Eco Start Stop button lights up with the engine running
the only issue now is that the Eco Start Stop symbol doesn’t show on the dashboard nor the engine shuts off
bellow are few pictures to show the fix
Thanks @MBenzOwner @Cosworth2000 and @stockbmw for the inputs
Old Oct 27, 2022 | 02:27 AM
duchbk123's Avatar
c200
Good UB and IB numbers, quite similar to my car
Old Dec 20, 2022 | 10:32 PM
Mikedami's Avatar
Mercedes Benz C43
Should the IB number be below 5 A once the battery is fully charged? My UB is at 14.7 and IB 2.
Old Feb 2, 2023 | 07:57 PM
jjkh58's Avatar
2017 Merc C200 coupe
Hi - I have the same question as Mikedemi - What is ideal reading of IB should be at both idling and driving? My UB is stable at 14.3 when idling/ driving and IB goes from negative to plus when I start the engine. However, the IB gradually drops and stays around the 3~6 no matter whether the car is idling or driving.
I have seen so many articles about UB but not many around what IB should be? I guess if it goes negative while driving then for sure its a problem but if it stays within the plus range. What is ideal for IB? and why its dropping when the engine is on while the UB is stable?
