2018 C300 with sport suspension
) until I have been driving for some time and noticed big shocks when I drive over bumpy road. This is more obvious when Im driving on highway. My butt almost left the seat once because of the bad road condition. So, I don't know if the sport suspension could be adjusted and softened. I called the dealer and it's just phone transfer to another transfer and wait and wait....I know it would be very expensive to replace the entire sport suspension with a regular suspension. I'm not sure what to do. The tire pressure readings are 38 38 front and 41 41 rear. My car is RWD. The pressure suggestion on the gas cap is normal load 36 and max load 39 for the front and 36 45 for the rear. I think lower the tire pressure probably would not do any help. I definitely prefer the more comfortable and smooth drive. Just want to seeking some great suggestions or any comments from you guys. Thank you very much.
I have 19" wheels and I run my tires between 32 and 34 PSI cold all around. If I bump them up to ~40 PSI cold I can feel the difference, gets noticeably harder.
https://www.knowyourparts.com/techni...ing-tire-wear/
If your tires are run-flats, that's most likely a big factor. If they are run-flats, I would swap to non run-flats as soon as you can:
https://www.autoweek.com/car-life/a2...and-tradeoffs/
Beyond that, if you do your own work or have the means, I would check your struts for any signs of leakage (oil seepage) and depending on your mileage, maybe consider some good replacement struts.
If you are looking for tire opinions/recommendations, I would recommend Michelin Pilot Sport AS4 tires. Excellent tire.
Good luck!
You dont have to replace them at the dealer any good tyre shop will do.
I got a spare wheel called "space saver". I just placed it in my trunk.
? Thanks: https://www.bigotires.com/tires/sku/...254518_2454018
? Thanks: https://www.bigotires.com/tires/sku/...254518_2454018Dude, if those are the kind of tires you're looking at, I'm not sure what to say. Stay safe and I wish you the best on your perilous journey of discovery?
