Rough idle
Old Nov 30, 2021 | 09:50 PM
Hello32's Avatar
C300
Rough idle
I have a 2015 c300 with about 105k miles. When at a full stop or in park my car doesn’t have the smoothest Idle. Some may not notice it but I defiantly can. Just little hiccups nothing major. Anyone know what this could be? I replaced 2 fuel injectors, all ignition coils and all the spark plugs a couple months ago because I was having a misfire issue but car has been running fine since then. Any guidance would be appreciated.
Old Dec 2, 2021 | 12:00 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
plugged Lambda...
Just replace your primary Lambda-O2 sensor. This causes your idle mixture to be off by a little.... busted PCV air leak can help screw that up too.
Last reset the ECU to speed up relearning the mixture map, specifically idle. After that your engine will have smoother low rpm torque again.
Old Dec 2, 2021 | 03:32 AM
Hello32's Avatar
C300
Excellent. I will replace the sensor. How do you reset the ecu?
Old Dec 2, 2021 | 03:34 AM
Hello32's Avatar
C300
Also I see upstream left and right sensors, do you know what one I should change?
Old Dec 2, 2021 | 03:59 AM
both upstream only
both upstream so they read the same as close as possible to each other.
You'll need to use a scanner to reset the ECU. Once you got the sensors replaced, leave them disconnected. This will trigger couple ECU errors that you'll be able to reset. That will cause ECU to relearn mixtures using the new sensors you will have then connected.
Old Dec 2, 2021 | 04:52 AM
check running voltage...
Check your running voltage is around 14.4v and float your battery overnight.
This will temporarily rule out unregulated low voltage.
Old Dec 2, 2021 | 08:38 AM
Hello32's Avatar
C300
ok just to confirm, the downstream sensors do not need to be changed?
Old Dec 2, 2021 | 12:09 PM
yes, exactly. ​​​​​​Downstream O2 are just checking the cats efficiency. Unrelated to your problem.
The upstream sensors directly feedback to the fuel injection control. They get partially plugged up and partially fail without code because their reference output is still indicative.
Make sure your scanner can interact with the ECU module before you trigger faults mentioned above (Just saying: don't cause faults if you have no tool to reset ECU).
