My W205 C300 Base Brakes Conversion/Upgrade Project
- Larger and smoother-faced calipers that will take paint well
- Larger drilled and slotted rotors
- Matching front and rear rotor diameters
- Minimal amount of customization
- Keep it under $2000 if possible
Since I just made the decision to do this very recently (after dagger22 rightly pointed out that the stock brakes look weak on my setup... which I knew... I just needed some motivation to do something about it
), I have things to learn. So... if any of you have any input or advice, it is appreciated!I've already decided I'm doing C43 brakes on the front, which the rotors are 360mm x 36mm. To match the rotor size on the rear (and for better-looking calipers) it looks like my best path is to do C63 brakes on the rear, in which the rotors are 360mm x 26mm. The rear C63 brakes are my greatest unknown for proper fitment and is what I need some help with from those who may have done it or have the knowledge.
This will most likely be a slow process, as my life is somewhat busy and I prefer to do most work myself so finding the extra time to do these things is my greatest challenge. I will update this thread as I go along and I hope this will serve as a good example for those wanting to do the same!
I just purchased two front calipers taken off a 2020 C43 to get the ball rolling.
$268.92 each.
Total: $537.84
- https://mbworld.org/forums/c63-amg-w...or-code-2.html
- https://www.g2usa.com/product/CBCP-548.html
and any options to go custom color?
I will be going for the newer AMG GT yellow. ;D
here’s your reference to the rear C63s brakes upgrade. You will need to replace the electronic brake pedal cable, part number shown in pic.
Other than that it should fit well. Do take note the rotor hub is thicker so it will make your wheel offset jut out a few mm more.
do check as well the caliper alignment to ensure it is equal gap distance between the inner and outer rotor, this can be easily resolved with washers/shims, if its not equal.
I haven't made the final decision of what color I'm going with yet, but I'm considering the following (in order):
#1: MB caliper red (pretty sure I'll go "safe" with red ATM)
#2: MB caliper yellow
#3 Metallic copper
#4 Metallic dark gold-ish (similar to the MB ceramic calipers)
#5 Metallic Petronas green
I do not have a lot of clearance between the valve stem and the caliper, so I'm hoping the C43 calipers do not expand the circumference too much. I'll have to wait a bit and see by doing a trial fitment of the new calipers.
https://www.r1concepts.com
TIA
This is a slow-rolling project, but I'm getting one step closer!
I just purchased two rear C63 calipers off a 2018 C63 sedan. I've been watching eBay for some time and set a search notification... got an email this morning that this pair was just listed, so I snagged them!
Pair Price: $563.39
Total w/Tax & Shipping: $626.64
https://mbworld.org/forums/market/839677
Pair Price: $563.39
For brake pads, you can look for Powerstop Z17 or Z23, they are ceramic pads.... very very little dust and good braking power.
It was a sign, lol. I knew I had to do eeet!Thanks for the pad recommendation. I'm pretty sure I'm going with R1 Concepts Carbon GEOMET drilled and slotted rotors.
When I was younger, power was everything. This is no longer my top priority.
Any toolbag with a heartbeat and a credit score can rock a C63/C43/C450/C400 and feel on top of the world. I have great respect and more appreciation for cars that have blood, sweat and tears poured into them by their owners and have individual personality... something that cannot be delivered from the factory or obtained by signing on the dotted line.
"Saving money" is all in how you calculate your math and what's important to you. As an example, here is how I justify my expenses on this car:
I purchased my low-mileage 2015 C300 in 2018 for $22K.
To date, I've put approximately $15K into the car.
So I'm about $37K in.
If I would have purchased this car new and paid it off, the sticker was $52K.
In the end, I would have paid $52K and still had a bone-stock C300. Today I'm at $37K and have something that can't be bought at a MB dealer.
I no longer need these calipers and would like to sell them. I never even opened the boxes they came in.
2 front calipers off a 2020 C43
2 rear calipers off a 2018 C63
I paid $1100 for the set.
Looking to sell to a member here for $800 and I'll pay 50% of the shipping cost within the lower 48 US states.
(I'll let this hang here for a while before I post them on Ebay for $900 +100% shipping)
However, I can do this: I can modify my Ebay listing to accept offers and I will accept an offer from you at $100 off on each pair which would bring the total to $829 and you would pay the total shipping from Florida.
If this works for you, let me know when you're ready to commit on Ebay and I will open the listings to offers.
Thanks!
https://www.ebay.com/itm/354730213213
https://www.ebay.com/itm/354730203370
I know it could be a bit late because you sold the car and forgot upgrade but don't know if you (or someone) could answer a question.
I am trying to retrofit C43 front brakes in my S205 (2016). Rotors are 360mm, but don't know if they would fit in my 18 inch rims 5 spoke wheel.
Thanks in advance
Thanks in advance
i have a 2019 c300 base model non 4matic. I just purchases 2017 c43 calipers. What size rotors do i need to make this work for a non 4matic base model?
