mercedes w205, engine overheating with a / c on!
I changed absolutely everything, the pump, the thermostat, the fan works well, I cleaned the radiator 2 times, updated the firmware, the air conditioner blows cold, so I believe that everything is fine with the compressor, today I replaced the compressor valve, there was an error on it, but it did not help, overheating after 5 km again.
computer check did not give any results
also, coolant level is ok
Mercedes Benz c300, w205, 2014-2015, 71,5k miles.
https://youtube.com/shorts/UXH42fG6rFI?feature=share
I already hate the brand "MB"
I've read through your thread. You're saying you're overheating in red temp zone. You've replaced a comprehensive set of parts without immediate success.
>> Good chance your engine TEMP Sensor is leaking coolant in its connector.
Oxidation is creating poor contacts. Closely inspect visually + observe live data with scanner or replace
The fact you are reaching the Red Temp zone means it's NOT the A/C pressure switch.
