Replaced original steering wheel with a Glc and now vibration does not work.
Old Jul 24, 2022 | 07:48 AM
Eni Xh's Avatar
c class
Hello. I originally had a round steering wheel (shown in the first photo) with vibration and heating and changed it to a Amg flat bottom from a Glc with vibration only (shown in the second photo). Problem is now the vibration is not working, any knowledge to how do i deal and fix it? I understand i will never have heating with that steering wheel again i don't mind it but vibration should work right? Please help.
Original steering wheel.
Replacement Glc steering wheel.
Old Jul 24, 2022 | 11:32 AM
Andy74's Avatar
W205 2015
I am sorry i can't help but i am curious why did you do the swap i really can't see much difference. Since this Glc steering wheel is not working for you why dont you condider an amg steering wheel many guys are doing the swap including myself. I dont have heating or vibration i frankly dont care about both.
Old Jul 24, 2022 | 01:35 PM
sids2112's Avatar
2021 C300 4MATIC
What do you mean by ‘vibration does not work’? Are you referring to the lane departure warning feedback?
Old Jul 24, 2022 | 05:26 PM
W205C43PFL's Avatar
Originally Posted by Andy74
I am sorry i can't help but i am curious why did you do the swap i really can't see much difference. Since this Glc steering wheel why dont you condider an amg steering wheel many guys are doing the swap including myself. I dont have heating or vibration i frankly dont care about both.
Curious as well, other than that, looks like the new one swapped in is the amg line one from pre-facelift models which based on the original wheel, OP has a pre-facelift.
Old Jul 24, 2022 | 05:29 PM
W205C43PFL's Avatar
That sounds like what OP is talking about, I wonder if the motor needs to be installed in the steering wheel too. As in the steering wheel don't come with it if the vehicle it was originally from wasn't option those driver assist features? Unless the motor is present but it is just coding.
Old Jul 25, 2022 | 12:01 AM
lthlc63's Avatar
04 E55, 06 E55, 05 G55, 14 E63s, 12 cls63
take all the old componants out of your wheel and install in the new amg wheel. everything should work.
Old Jul 25, 2022 | 02:10 AM
Eni Xh's Avatar
c class
Thank you for your reply, i did the swap because the flap bottom looks more sporty for me and i wanted to refresh my experience a little bit.
Old Jul 25, 2022 | 02:11 AM
Eni Xh's Avatar
c class
exactly it’s the prefacelift model, i had the option to swap it for a facelift one but i wanted to stay “original” just have the flat bottom steering wheel
Old Jul 25, 2022 | 02:15 AM
Eni Xh's Avatar
c class
yes exactly, i just called it vibro because I couldn’t remember the name.
Old Jul 25, 2022 | 02:18 AM
Eni Xh's Avatar
c class
Motor is present. The Glc that the wheel came from had vibro, it’s just not working on my car now. “My car has vibro and heating option” so it’s compatible
Old Jul 25, 2022 | 02:20 AM
Eni Xh's Avatar
c class
too late, already gave my steering wheel to someone, this has been 1-2 months ago but i never noticed the vibration is not working until i made odb2 scan
Old Jul 25, 2022 | 11:12 AM
W205C43PFL's Avatar
Sounds like something needs to be coded if the the hardware is intact...
Old Jul 25, 2022 | 06:11 PM
Eni Xh's Avatar
c class
how do you code that?
Old Jul 25, 2022 | 09:23 PM
Andy74's Avatar
W205 2015
2019 AMG steering wheel on a 2015 C200 AMG line
Old Apr 18, 2024 | 10:49 PM
Sambugnet's Avatar
W212
Hi, I have the same problem. What did you found with te OBD2 scan?
