2017 C43 Buttons not working
#51
FINALLY FIXED
I checked my fuses and they were good and made sure all my connections were connected good as well.
So after speaking with a friend of mine who works as a tech at Mercedes and sees this issue pretty often he told me that most likely the motherboards on the switch blocks were fried and so I had to buy and install new ones.
$133 for the left and $80 for the right..spent $213 and installed them today and glad to say it worked!
Removed entire block
On the sides you’ll see these clips which you’ll lift up there should only be two on each side
I used a small flat head to lift up the clips. Once you pull out the old one, you can insert the new ones and screw everything back into place!
After plugging everything back in.. I turned on my car and the lights and all my buttons were working again! Took forever to finally get it fixed but glad I can enjoy my car again! Hope this serves as some help to those going through the same issue who are stuck and not sure what may be going on!
benzdude (07-29-2023)
#52
Received 2,721 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
