Multiple issues: trany jerking, low rpm at idle, can't autostart after stop
Old Sep 18, 2025 | 01:35 PM
sulsj's Avatar
2015 c300
Hi,
Would like to get some advice.
2015 c300 rwd. I ran it for 39,000mi. Yeh it's a leisure car.
Recently, it's jerking in changing gears, esp. at d2->d3 (fyi, no tranny fluid changed yet).
And the rpm at idle stays b/w 500~550 so it's shaking intermittently. Sometimes it's almost turned itself off.
And it's not autostarted at a stop one time a few days ago.
No error code found but I am going to put it into the dealership for checking soon.
Any similar experience or advice will be welcomed.
Thank you!
Old Sep 19, 2025 | 06:36 PM
Cosworth2000's Avatar
2022 E53 AMG
You may get a code soon or there is one already but it does not throw a CEL or a cheap OBD reader will not read the code in the modules.
Until you get a code, it will be hard for anyone to help you with a direction. Hopefully MB can help you find a solution and fix.
Old Sep 30, 2025 | 05:38 PM
sulsj's Avatar
2015 c300
I burned $297 for inspection and they reported it's a crankshaft position sensor malfunction (P033904).
And they found a cracked rear flex disc.
The estimates are $1400 and $874 each.
Any advice?
Old Oct 1, 2025 | 05:00 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Any advice?
I find it really odd that faulty crankshaft CKP did not trigger CEL and not log any fault: near impossible!
If you had said... oily camshaft CPS sensors then yes.
Old Oct 1, 2025 | 05:27 PM
sulsj's Avatar
2015 c300
Yes, I agree. No warning lights on. Maybe just dirty or oily or not sick enough.
Old Oct 1, 2025 | 05:35 PM
Yes, I agree.
Well know more soon enough.
knock on wood.
Old Oct 1, 2025 | 09:30 PM
sulsj's Avatar
2015 c300
