need rec for usbc dashcam storage
I'll try reformatting the card and see if that helps, but does anyone have a recommendation that works reliably?
Thanks,
AJ
Thanks,
AJ
I have 2 of these in the car. One goes in the (E-class Sedan) in the caddy under my right elbow, and the other goes next to the 12v (cig lighter) connector, under the center of the dashboard. Both of them show up and either can be used for storage for the Dashcam and either can be used simultaneously for playback of Media on the Right LCD panel.
I read people with the current E Class complaining they have to turn on the dashcam every time they start their car, otherwise it won't record anything.
Is that also true for the new C Class?
Hardware wise do you need to have AR option? I’ve seen that said, but because all models have a forward camera even for sign recognition I’m not sure if it’s true and why?
I'm not sure what options or trim level is required but if you put your vin number into the website it will tell you what options are available. I added SanDisk thumb drive from Amazon and formatted with exFat. It will work from any of my three usbc ports and easily lets me view the video on my pc. It's also easy to review the videos in the car. I'm sure any size would work, but the 512GB will give you days of continuous recording. You can set loop recording that will overwrite the oldest video once the card is full and will start automatically when the car starts. Each video is about 250 MB and 2 minutes long. Video quality is very good at 1920 X1280 resolution. Note that the dashcam is only using the forward-facing camera mounted behind the rear-view mirror.
. The size difference between ocasional snapshots and daily video recordings is significant though.
