Rear Window Defroster issue
Hi All,
I picked up 2023 c300 this January, and never used the rear window defroster until recently.
What I found out as soon as I pushed the defrost button when it was foggy inside was that the top third of the rear window was not defrosted while the rest of the bottom was cleared.
So, I checked the gird lines and apparently the top few horizontal lines were isolated from the end points from which the current come through(also confirmed with my voltmeter)
Does anyone have the similar issue? or is this intentional by the manufacturer? I have never seen any car with a partial rear window defroster.
Thank you in advance for sharing your thoughts!
I have already contacted the dealer with a picture showing the grid lines disconnected, but he claims it is normal saying that other cars in the show room also have the disconnections.
My dealership is 2 hours away, so I just can't go visit.
Now, I just called a service center in my town and booked an appointment in two weeks.
I am really curious if this is a common issue. If not, why would they put some meaningless conductive 4-5 lines in the top?(getting no voltage so no defrosting).
PeterUbers (03-06-2023)
I see the same on my rear window. I have no problem with defroster. It may that top part is not meant to be defrosted and those lines are not heaters but antennas for radio and stuff.
Yeah the antenna is located in the back windshield. I have to look at mine to make sure but I think that is normal. When you tested the voltage, what did you get?
It was some snow today and I see that very top of rear glass doesn't defrost (it defrosts eventually when glass itself heats up but not right away). So those lines are indeed antennas but heaters.
Since this seems to be by design on every 206, has anyone noticed it hindering visibility through the rear window after the defroster has reduced condensation?
How could the discontinuations are intended by design? If a conductive line is not connected to anywhere, it cannot work as radio antennas or anything else(maybe I am just ignorant about something).
Received 2,626 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
I get 12-13 voltages on those lines that have connections to both end sides(left & right), but the lines(mostly top few horizontal lines) that are isolated as seen in the above pics have zero voltage.
By the way OP, by design or not I was able to confirm that is how it is on my W205 (so one generation older than your vehicle OP)
It can be just for decoration purpose to keep look consistent. The one thing is clear that it's not some defect since all cars have it in the same way.
So I tried to find some informative postings online, and read about defroster lines interfering radio signals if they share the grid lines.
But, it still does not make sense to me. To me, regardless of the radio antenna or whatever, it seems a defect that top third is not frosted as seen in the pic (it wouldnt be defrosted even after 10 minutes).
Maybe I will simply have to admit it is the way it is.
Also you can tuck the cables in nicely around rear window, and completely hide them.
I can explain more or answer any question you may have to install a dashcam on w206.
giovane (03-13-2023)
Please open a new thread,,and please share pictures.
I'm mostly interested on how you tucked the cable and how you reached the fuse box in the trunk. Also take a picture of the fuses you tapped into.
I will be so grateful. Thank you.
ps I wrote a therad on the Audi forum years ago when I installed a garmin dashcam in my A7
https://www.audiworld.com/forums/a7-...-mini-2989144/
dnvnlee (03-13-2023)
Sure, I will try to post something that might be helpful for others looking to install a dashcam on w206.
The car is actually my wife's daily commuter into city(Manhattan), I will try to take photo on how I have done over the weekend although I dont have any pic taken while installing.
