MyQ connected garage + MBUX
Experience the power of voice
myQ Connected Garage is available in select 2019 and newer Mercedes-Benz vehicles via the MBUX Voice Assistant. Mercedes-Benz drivers with a myQ connected garage door opener are the first to have their own in-vehicle, voice-controlled personal assistant to open, close and check the status of their garage door from anywhere on the road.Link Your Mercedes-Benz to myQ Connected Garage
Link your Mercedes-Benz to your myQ account to enable integrated garage access controls. See below for instructions.Tips for Getting Started
- Use the myQ Compatibility Tool to determine if your garage door opener is myQ compatible.
- If you are new to myQ, download the myQ mobile app onto your mobile device, create an account, and sign in.
- Connect your myQ-connected garage door devices via myQ mobile app using the onscreen setup tutorial and ensure they are controllable via myQ mobile app prior to linking.
- Be sure your vehicle is parked safely either inside or outside of your garage prior to beginning.
- Ensure there are no garage door obstructions.
To Link Your Mercedes-Benz to myQ Connected Garage
- Power on your vehicle in the parked position.
- Say “Hey Mercedes, I want to connect my myQ Connected Garage account.”
- The Vehicle will respond with “Okay, I’ve just sent through a QR code notification. To see it, just swipe down from the top of your screen and tap the notification. You can then simply scan the QR code with your phone and connect to your myQ Connected Garage account.”
- Scan the QR Code using your mobile device.
- This will take you to a Mercedes-Benz + myQ Connected Garage webpage.
- On your mobile device, tap Sign In if you are an existing myQ User.
- If you are a new myQ user, tap Learn More to get signed up.
- Review ‘Consent’ and tap Accept.
- Your vehicle is now linked to your myQ garage door devices.
EDIT: Just connected mine. Yes to the above and you can also ask the status of the garage door which is great because sometimes I'll be halfway down street thinking that I forgot to close the door and have to look at my phone's MyQ app to check the status of the door. Thanks for posting.
What other apps can I connect besides Alexa which I don't use?
The new MBUX Voice Assistant smart home feature supports products from Philips Hue, Samsung SmartThings, TP-Link, and myQ by Chamberlain Group. Devices and equipment users can control include lights, smart plugs, thermostats, motion detectors, and garage doors.
I would prefer to use Google over MBUX since Google has user voice recognition as a little bit of a security layer.
I think the most useful integration of MyQ and MBUX is the ability to ask Mercedes for the status of my garage door because often times I'll drive away and can't remember if I closed it via homelink. Before I would have to open the MyQ app on my phone to look at the status so it's just a little bit of convenience in this regard. From there I can ask to close it if I left it open without having to be within homelink range, even though I have my Liftmaster set to auto close after 10min.
Another user on here said he has his automated to close via geofence so that would make this integration moot for me if I'm able to do the same on my garage.
Garage door status on the CarPlay dashboard:
Native iOS lock screen widget showing the home status:
Like this:
I don't get a QR code I get this message.......In order to use the feature, please login to your Mercedes Me profile account...blah blah
umm my profile is loggin and running.
Both Mercedes and Chamberlain say I should be getting a QR code to scan. Clearly I'm not or I wouldn't be reaching out to these people for help.
Beyond flustered.
2021 GLE 53 AMG
Beyond flustered.
2021 GLE 53 AMG
Beyond flustered.
2021 GLE 53 AMG
