C218 CLS63, 2011 - 2019
KW Suspension Solutions | KW Height Adjustable Sleeve Kits in Stock for '12 CLS 63
Old Mar 14, 2012 | 11:05 AM
oliver@velosdesignwerks.com's Avatar
Former Vendor of MBWorld
AMG
Hello Members,
We have a few KW Sleeve Kits in stock for the 2012 CLS63. Feel free to shoot us a PM or give us a call for promo pricing.
Retail is $1029.99
Best Regards,
Old Mar 14, 2012 | 09:40 PM
sultanC36's Avatar
do you have somthing for the W219 ??
Old Mar 15, 2012 | 09:50 AM
AMG
PM sent!
Old Mar 15, 2012 | 10:39 AM
sultanC36's Avatar
i am wondring do you have coilover system for the W219
Old Mar 15, 2012 | 10:47 AM
Vic55's Avatar
Administrator
The KW system is for the later models with steel springs up front. Your car, the 219, runs airmatic all the way around. You can get lowering modules from Renntech, Kleemann, etc but this kit will not work.
Old Mar 15, 2012 | 01:59 PM
AMG
Correct. Thanks.
This kit is advertised for the '12 CLS63 with spring/shock up front and air in the rear... Also works on a few other models that share similar setup.
Old Mar 15, 2012 | 05:31 PM
Big Al22's Avatar
2012 Cls63 AMG - 2010 S550 4matic amg package - 2000 G500 straight from Germany
Pm price. Thanks
Ali
Old Mar 15, 2012 | 05:36 PM
AMG
Originally Posted by Big Al22
Pm price. Thanks
Ali
PM sent
Old Mar 15, 2012 | 11:24 PM
pgordon888's Avatar
2014 GT-R; 2014 GL 350 BTC
Originally Posted by VelosDesignwerks
PM sent
Getting mine installed with some spacers tomorrow finally.
Old Mar 16, 2012 | 04:40 PM
AMG
Old Mar 16, 2012 | 09:12 PM
pgordon888's Avatar
Here is the teaser shot I was sent today.Won't be able to pick it up till Monday.
20 mm drop front and back with 10mm front / 15 mm rear spacer as per the helpful input from those on this forum.
Attached Thumbnails KW Suspension Solutions | KW Height Adjustable Sleeve Kits in Stock for '12 CLS 63-img_0357.jpg
Old Mar 19, 2012 | 10:30 AM
AMG
Nice! thanks for sharing
Old Mar 19, 2012 | 01:07 PM
vdubpower's Avatar
i drive them all, fast and hard
pgordon, is that teaser shot after the lowering, to me it looks stock, but i guess after looking at vic55's car pics, nothing seems lowered compared to his
Old Mar 19, 2012 | 01:30 PM
Vic55's Avatar
Administrator
And 20mm is only 8/10ths of an inch--- I dropped mine probably closer to 40mm.
Old Mar 19, 2012 | 03:08 PM
Liquid1's Avatar
2012 CLS550
PM sent for info on the '12 CLS550. TIA
Old Mar 19, 2012 | 08:43 PM
pgordon888's Avatar
The attached thumbnail is post lowering. The picture in my signature line is pre lowering. I will try to get some better shots during the day tomorrow. Close ups will give you a better idea of what the 20 mm drop looks like. I can't see going lower than 20mm if you live in the northeast given road conditions but if I lived in cali or south Florida I would be slammed like Vic's car.
Quick question for others who have this mod. Does anyone know if there are shims or camber plates available to adjust for the camber change from the drop? The installer said he was going to look for some and that I had a little bit of camber change even after the alignment for the drop that would give me some inside accelerated tire wear. He said that other brands typically have after market solutions to adjust for this (my shop does mostly BMW work).
Old Mar 19, 2012 | 09:58 PM
pgordon888's Avatar
Here is a better picture.
Attached Thumbnails KW Suspension Solutions | KW Height Adjustable Sleeve Kits in Stock for '12 CLS 63-img_0368.jpg
Old Mar 19, 2012 | 10:08 PM
Vic55's Avatar
Administrator
Whats funny is Im actually not what one would called "slammed" here in Cali. My fenders are about are about 1/2 fingers width from the tires. I maintained some good function along with form. But I am witnessing inner tire wear in the rears. Oh well you gotta pay to play.
Old Mar 19, 2012 | 10:54 PM
pgordon888's Avatar
Well by Philly/NYC standards you would be slammed or at least when you hit your first pothole.
On the tire wear, looks like there was a camber kit for the C219 CLS available from several companies...hopefully there will be one coming out for the C218 as well.
As long as I can get at least 6K miles out of my rear tires I can handle the negative camber. It improves handling anyhow even if it shreds tires.
Old Mar 20, 2012 | 10:29 AM
Vic55's Avatar
Administrator
Im just gonna get my Toe set so I can make sure no scrubbing... often toe is the true culprit in tire wear.
Old Mar 20, 2012 | 12:21 PM
FlyC63's Avatar
12 E63 matte white
Where do you go for your alignment? would they know you would need you Toe set or you have to tell them?
Old Mar 20, 2012 | 12:39 PM
Vic55's Avatar
Administrator
West End Alignment or if Im down South, Beckers ---- they will know for sure. But not every layman understands that toe leads to more tirewear than camber.
Old Mar 20, 2012 | 01:31 PM
FlyC63's Avatar
12 E63 matte white
Thank you..very helpful!
