Creak from the dashboard area (C218)
2012 MB CLS63, 2012 Le Man Red SLS
Hi there,
Has anybody experience excessive creaking noise coming from the dashboard area? I took my car in a few weeks ago to address this issue but the noise reappeared a few days after I picked up my car. The dealer removed the dashboard and added insulation to it to reduce the noise but it's still there and can be quite loud at times.
I was just wondering if anybody else has experienced this problem and what solutions did you (or the dealer) do to address this problem? My car currently has about 7000 miles.
Administrator
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
Hi there,
Where on the dashboard, its a pretty big area?
Received 3,404 Likes
2012 CLS63
have only had a slight creak on my driver side, near my window.....
but not enough to be concerned.......
good luck with it...
C218 CLS63TT PP Edition1, W213 E63S
Hi there,
there is a fix for it , the one for speedometer.
you can put your thump and make it stop, i used 3M two side tape and stuffed it between the two plastics
never heard it creaking again.
cheap and less than 5 minutes, dealer will open the whole dashboard to insirt a small plastic there.
Ali,
Can you take a picture of this plastic insert on your dashboard? I use my thumb too, to stop the damn creak! I also find the creak to be sensitive to temperature change as well.
i don't have my car now, but it was also temperature to sensitive, if the dashboard is hot it doesn't creak, if it is cold it shrinks and creak, i noticed it the first day i got the car. and i am sure it is the same plastic above speedometer.
you can take it to the dealer or pull it down a bit and stick 3M double side tape and keep pressing it until it dry.
