C218 CLS63, 2011 - 2019
W218 CLS63 KW Suspension firmer than PP?
Old Aug 24, 2012 | 05:33 PM
CLS63W218's Avatar
2012 CLS 63, 2013 Gallardo LP550
KW's front coil over suspension kit. Is it firmer than the optional MB Performance Package setup or about the same?
Old Aug 24, 2012 | 09:46 PM
vdubpower's Avatar
i drive them all, fast and hard
will let vic answer, he has the best sense of suspension difference
Old Aug 25, 2012 | 02:06 PM
Polivoks's Avatar
2012 CLS63 AMG
I can say it is slightly firmer than the stock non-PP suspension, not sure about the PP suspension.
Old Aug 26, 2012 | 01:34 AM
drop997stop's Avatar
08 E 6point3-sold- 11 caddy cts-v-sold, 2012 E63 Palladium Silver
Kw
The kw are a bit firmer but it all depends on low you go. They are sleeves and just replace the front springs. The rear is not changed except for height. It does get a bit firmer the lower you go.
I went with the kw st up and advance performance adj rear link on my e63. I do not have p30
QUOTE=CLS63W218;5333243]KW's front coil over suspension kit. Is it firmer than the optional MB Performance Package setup or about the same?[/QUOTE]
Old Aug 26, 2012 | 01:11 PM
Vic55's Avatar
Administrator
Id actually say yes and no.... The PP is very stiff and at times it can be too rough for some even on the streets and no so great roads. I find that the KW actually becomes a bit more compliant with bad roads and minor undulations yet is very taut at higher speeds and in turns (where its needed).
Either way I would get the KW. The sleeve unit assists better in hard turn ins and keeps the roll out.
Old Aug 26, 2012 | 02:04 PM
saifsaif's Avatar
The pp use stiffer shocks , but same spring , kw spring is stiffer than oem spring , so kw spring on pp shocks is stiffer than kw on non pp .
Old Jul 27, 2016 | 11:52 PM
rolling18's Avatar
2012 CLS63s White
anyone interested in selling their Stock Springs/ spring perches? or any other stock strut parts?
Old Aug 14, 2016 | 03:57 AM
rolling18's Avatar
2012 CLS63s White
no one??
