OE tuned 2013 CLS63 PP [Dyno sheet]
Dyno sheet stock vs tune
Just to let you know guy I didn't take AFR reading on stock runs
Car is running on 91 octane and it has K&N filters
Others reported more like 100 crank whereas this is about 65.
Not trying to start a tuner war discussion, just was wondering what you were sold.
The first run after tune was 514whp then 530whp the more it get hotter the more increase in hp that was on 91octane I think on 100octane +20whp more maybe
i know you will love it.
the car will become stronger after driving it harder, i tested mine against couple of tunes on street, and i walk on them easily.
The OE tune has never caused me a plug foul or a CEL either.
I hear people talk about peak #s all the time which frustrates tuners. Its not about peak numbers. Much more heat is generated as you make more power at the top of the curve, where detonation can come into play which we all know can hurt the motor. This needs to be taken into consideration, I like to see large gains down low in torque and a steady gain in HP through the curve. Thats what makes a great tuner, great
The stock tune doesn't make 500hp until 5300rpm and stays there for 100rpm until 5400 rpm and never recovers, after the tune HP stays well above 500 from 4300 and peaks around 5800. My jaw dropped when I saw the graph, its amazing how much power Mercedes left on the table.
Very good point on the curves. Very impressive indeed to get 500rwhp a few thousand rpm before. That makes a huge difference on the street
....so whens the tune to the m5
i only have a downpipe and a tune, no cooling mods or anything else and street tires.
As for the M5- no OBDII tune yet and I dont want to pull the ECU. BMW moves at much faster level when it comes to mods/tunes so Im anticipating a tune ready in January. There are tunes out already but not OBDII tunes.
Here was my OE tuning dyno and rpm sheet:
I understand how the dyno works. I think you missed the point. People look at peak #s instead of looking at the curve and the gains made through the range between pre and after tune. You can have a tune with a peak hp or tq number from lets say 5k to 53k and find that impressive, yet the rest of the curve gains are mediocre. My point.
Just an FYI...your wrong about not spooling the turbos faster. I've seen tuners play with fuel and timing to get higher egt's which translates into faster spool.
that is right, peak numbers are not the most important thing here, but the gains through the whole RPM line.
believe me, i smoked some tuned M157s that claim they are 20-30hp more than me based on their dyno high peak results.
