C218 CLS63, 2011 - 2019
Weistec Tune Dyno Sheet (Weird Numbers!)
Old Aug 16, 2013 | 04:02 AM
E-SICKTY3's Avatar
'13 CLS63 PP, '16 Huracan , '11 RR Ghost
Exclamation Weistec Tune Dyno Sheet (Weird Numbers!)
After having my car tuned for a while -- I finally had the chance to dyno my car. Unfortunately no before dyno but after seeing other dyno results, these numbers seem pretty low... I'm running their spark plugs and K&N drop in air filter. I have no idea what happened here, with the dip on the torque curve.
Had my shop contacted Weistec and faxed over the dyno sheet, they said they will call back but haven't receive any call back (waited for hours).
Any thoughts?
Old Aug 16, 2013 | 11:50 AM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
how many runs did you do on the dyno ?
did you set the car on dyno mode ?
Old Aug 16, 2013 | 01:47 PM
vdubpower's Avatar
i drive them all, fast and hard
The numbers are of a non tuned car. HP and torque.
My pp car dynoed at 501/540
You should be atleast 100 up on me. Good luck
Old Aug 16, 2013 | 02:04 PM
Weistec's Avatar
Former Vendor of MBWorld
Weistec
Any thoughts?
Hello,
We only received a fax with the dyno sheet but no contact via telephone was made. Is there a contact number we can reach you or the installing shop at, and we will be happy to follow up immediately. Please PM us the information. Thank you.
Weistec Engineering
Old Aug 16, 2013 | 02:36 PM
E-SICKTY3's Avatar
I did 4 runs on the dyno -- all got the same range of numbers and yes it was on dyno mode.
Originally Posted by Weistec
Hello,
Weistec Engineering
My shop did called you via telephone -- Darwin was talking to Sean and told us that Anthony or someone from Weistec would call us back. I did not have the shop install the ECU but it was ordered through them and I personally drove to LA to get the ECU tuned.
PM you shortly
Old Aug 16, 2013 | 02:47 PM
Vic55's Avatar
Administrator
What gear was this done in?? Numbers are way too low....
Old Aug 16, 2013 | 02:48 PM
E-SICKTY3's Avatar
4th gear
Old Aug 16, 2013 | 02:49 PM
xtyper's Avatar
2013 E63 AMG
Any thoughts?
As others have said, those results look in line with a stock Performance Package car. Does your car have PP? If so, have you taken it in since the tune for any service where the dealer might have flashed the ECU?
Old Aug 16, 2013 | 02:56 PM
E-SICKTY3's Avatar
Yes, my car have PP. Nope -- never been to the dealer after the tune. However, car does feel a little more responsive.
Old Aug 17, 2013 | 08:24 PM
alrasheed1991's Avatar
2011 C63AMG P31
did you feel a different before after tune ?if you did maybe dyno is broken ....
Old Sep 1, 2013 | 01:08 AM
drop997stop's Avatar
08 E 6point3-sold- 11 caddy cts-v-sold, 2012 E63 Palladium Silver
Tune
After the tune you should feel a night and day difference.
Any cel go off during any of the runs. Maybe a misfire
Old Sep 5, 2013 | 04:09 AM
E-SICKTY3's Avatar
No issues during the runs -- however, car feels faster. I actually pull away from my friend's GTR after 90mph+. His GTR has midpipe, downpipe, and exhaust.
I've been trying to have another dyno run into my schedule -- hopefully soon before Shift Sector.
How's your car running with the tune?
Old Sep 30, 2013 | 12:29 AM
Tune
Car runs good. For some reason I get the occasional cel but no limp mode and the car runs fine. Cycle the car and the cel is gone. Doesn't bother me. Running MBH downpipes with x pipe. Added high flow cats after. Smell was getting to me.
Hope it works out. Seems more m157 with tunes having problems than not
Old Sep 30, 2013 | 12:09 PM
Weistec's Avatar
Weistec
We will be at shift sector as well. We would be happy to take a look at the car to make sure it is running properly. Our guess is that something is going on with the dyno. We have done many of these cars and they are very consistent in power levels. Thanks and see you soon!
Weistec Engineering
Old Sep 30, 2013 | 12:13 PM
Weistec's Avatar
Weistec
We can supply you with a new set of spark plugs that will more than likely fix this issue. The stock spark plug will cause random misfires having identical symptoms to your car. Please feel free to email or call us anytime and we would be happy to assist. Thank you!
Weistec Engineering
Old Sep 30, 2013 | 07:39 PM
Faris63's Avatar
'13 CLS63 PP
If you walked away from a GT-R than your over +580WHP. I'm running Weistec tune for so long without any problem with the spark plugs (knock on wood) and their spark plugs is must for any tuned M157 or even stock cars
Old Oct 1, 2013 | 11:52 PM
E-SICKTY3's Avatar
Weistec Engineering
It would be great if you guys can a look at the car and make sure everything is running properly. I'm thinking the same way -- but Shift S3ctor should give the answer I will be at Sonic tent.
Thanks!
I hope so
I'm currently running their spark plugs as well and no issues of any kind. Also, I'm interested to check out your car if you are going to Shift Sector and maybe do a run just for fun. Yours have the upgraded turbo right?
Old Oct 2, 2013 | 01:51 AM
Faris63's Avatar
'13 CLS63 PP
Thanks!
I hope so
I'll be at Shift-S3ctor this weekend. We should do a run for fun no problem
I'm running Weistec tune + Weistec spark plugs + catless downpipes ( Not Weistec DP's ) that's all. The problem is I'll be running on HRE P40SC 20's with hankooks I hope they grip little bit lol
Old Oct 2, 2013 | 02:39 AM
vdubpower's Avatar
take lots of videos and pics.....ill try to goto the next one...cant this weekend..
Old Oct 2, 2013 | 01:11 PM
xtyper's Avatar
2013 E63 AMG
Thanks!
I hope so
I will be at Shift Sector as well this weekend with my tune/filters only 2013 E63, similar mods to your CLS63. I'd be happy to run you, as we should be side by side the whole way if your tune is running right, which I'm sure it is.
See you this weekend!
Old Oct 2, 2013 | 01:15 PM
xtyper's Avatar
2013 E63 AMG
Based on the way I've seen your car perform Faris at past airstrip events, it's a BEAST! The Weistec boys sure have your car dialed in and running strong. I've love a chance to run you to see how my car compares.
What gas do you typically run with your tune for these events?
Old Oct 2, 2013 | 02:54 PM
E-SICKTY3's Avatar
Sure. I'll be running on HRE S104 20" with hankooks as well lol
See you this weekend. I will look for your car or you can find me
That would be interesting to compare. We should do a run! See you this weekend
Old Oct 2, 2013 | 05:23 PM
Faris63's Avatar
'13 CLS63 PP
Thanks Eric. Your old E63 was a BEAST as well can't wait to see what this one does on the airstrip.
I always mix 50/50 91 with VP MS109 like 1/4 91 + 1/4 (5 gal) 109 = 1/2 of tank 100 octane to keep gas as low as possible for weight saving lol. See there guys
Old Oct 2, 2013 | 06:00 PM
Faris63's Avatar
'13 CLS63 PP
Does anyone have V-box to to 60-130 at the event ?
Old Oct 2, 2013 | 07:36 PM
xtyper's Avatar
2013 E63 AMG
I was thinking of bringing one, but decided against it when I saw the latest weather report. It's gonna be hot in the 90's, so really no point in recording 60-130 times since they will be suboptimal and not be representative of what our cars are really capable of.
