C218 CLS63, 2011 - 2019
Tyre help needed for HRE P44SC
Old Sep 6, 2013 | 10:08 PM
dre's Avatar
dre
CLS55, Lexus RX350, Radical SR8
Originally Posted by Ryan1
Dre -- Your new P44SC's are 19's right? Please be sure to post some pics when you get them installed. The P44SC is one of a handful of wheels on my 'short-list', so I', particularly interested in seeing how they look.
Yes, 19's. 20's would look better for sure but should be an improvement over stock. Should get time to try on some tyres next week so will post pics when it's done.
Old Sep 6, 2013 | 10:10 PM
dre's Avatar
dre
Originally Posted by Vic55
Thats a toss up, better tire vs a little more width. The width is not that much more with the rounder sidewall and....... on my M6 I have an 11 inch rear but at the time the only PSS was a 295x30x20 (no 305) so I kept that and I know Id rather have the PSS than a 305 Hankook on the M6. So Id go 295 PSS.
I think if the 305's don't fit, i'll go for the 295's.
Old Sep 6, 2013 | 10:15 PM
dre's Avatar
dre
Originally Posted by vdubpower
yes post lots of pics,......if possible, pre and post lowering
what made you choose the renntech spring system vs kw? thanks
Forgot to take pics pre lowering i"m afraid. I've gone pretty conservative on the lowering (26 inch ground to fender) until I put the wheels on. I'll take pics when it's all done.
No particular reasoning for going Renntech except that they had a local dealer.
Old Sep 7, 2013 | 06:18 AM
hyperion667's Avatar
2012 CLS63
are there other 305's that Michelin makes? I have some sort on my cls and tt
Old Sep 15, 2013 | 07:47 AM
dre's Avatar
dre
Tyres were put on today and I thought I'd share some quick pics. Apologies for the bad iPhone pics. Will try and take some better ones soon. I ended up going with Michelin Pilot Super Sport: 255/35/19 front and 295/30/19 rear. We tried putting on the 305/30/19 but it was rubbing even with my conservative lowering.
Attached Thumbnails Tyre help needed for HRE P44SC-p444.jpg   Tyre help needed for HRE P44SC-p445.jpg   Tyre help needed for HRE P44SC-p446.jpg   Tyre help needed for HRE P44SC-p447.jpg   Tyre help needed for HRE P44SC-p448.jpg
Old Sep 15, 2013 | 09:51 AM
emericr's Avatar
2021 Porsche TTS
Sweet set up. congrats.
I will be right behind you soon. I wonder why you could not go 305 as others have done it successfully.
Could this issue be wheel specific?
Old Sep 15, 2013 | 01:53 PM
  #32
vdubpower's Avatar
i drive them all, fast and hard
looks good
Old Sep 15, 2013 | 03:48 PM
  #33
2012 CLS63
nice
enjoy!
Old Sep 16, 2013 | 11:13 AM
  #34
Vic55's Avatar
Administrator
Good stuff Dre... glad it worked it right with the 295's.
Old Sep 16, 2013 | 03:12 PM
  #35
Steinhart's Avatar
2018 S 650, 2014 SL 550, 2017 911 TTS Cab, '13 F458 Spider
very nice
Old Sep 16, 2013 | 10:23 PM
  #36
dre's Avatar
dre
Thank you. I probably would've been able to fit the 305 if I had a slightly less aggressive offset on the wheel or went with a tyre with a 'rounder' sidewall like a Hankook.
looks good
nice
enjoy!
Originally Posted by Elliotts550SL
very nice
Thanks guys. Appreciate it.
Thanks Vic. Took your advise re PSS vs Hankook.
Old Sep 16, 2013 | 10:59 PM
  #37
vdubpower's Avatar
hows the suspension set up feel to YOu, pre and post lowering?
and feel free to post more pics , car looks real nice
Old Sep 19, 2013 | 06:37 AM
  #38
dre's Avatar
dre
Thanks. Car definitely feels flatter through bends which is a good thing. Comfort is not too bad - feels a little harsher but not unbearable by any means.
Old Sep 26, 2013 | 05:27 PM
  #39
Ryan1's Avatar
2014 CLS63-S Model
Looks Great! Very nice. Thanks for posting the pics.
How much do you think you lowered the car overall? Looks like about one inch below stock, but a little hard to guess from the pictures.
Congrats man.
Old Nov 12, 2013 | 11:19 AM
  #40
saifsaif's Avatar
Ok so I ran 20x9 and 20x11 with the same offsets so the "pushout" is the same and the diameter is very very very close since I ran a 30 series front and a 25 series rear.
I dropped my car and would rub for sure with PSS with my set up. I ran about 1/2 inch fender over tire. I went with the rounder sidewall to avoid issues (Hankook). The PSS is very very square so its almost like having an extra 3-5mm in offset pushing out. Id go with the Hankook to avoid rubbing but no doubt the PSS is the better tire. But the Hankook is very good for the price and I pushed the car extremely hard in straights and turns with no ill effects.
Need your advice vic , i am going to get hre p40sc 20x9 and 20x11 , same ofset as yours , r u saying Michelin will have some rub issue ? So should i go with hankook ? Going to lower the car too
Old Nov 12, 2013 | 11:38 AM
  #41
Vic55's Avatar
Administrator
If you run the same offsets as I did and drop the car you will more than likely rub with a PSS. I was very very close to rubbing on the Hankooks which are a very round tired. Japanese tires tend to be more round no doubt and you probably can run Toyo's too. I know my Hankooks did not rub on the CLS.
On a side note: I have a set of 21x11 wheels on my 991 with 305x25x21 PSS's and when the tires are side by side with my 20x11 SL63 with 305x30x20's - its very clear that the square wall of the PSS is not prevalent on the 21's. Im not sure what they did but their tires are far more round on the 21's than 20's and 19's.
Old Nov 12, 2013 | 11:58 AM
  #42
vdubpower's Avatar
Yeah I just put 295 30s pss on my e and there is a significant bulge compared to the 285 pzero. Its ok though. Looks mean. Car isn't lowered so no issues.
Old Nov 12, 2013 | 12:08 PM
  #43
2012 CLS63
okay! post these(991) in the 305 and up club; but don't let pert post a non Benz car there
Old Nov 12, 2013 | 12:16 PM
  #44
Vic55's Avatar
Administrator
I already did Hyp check it:
Click Here
Old Nov 12, 2013 | 03:48 PM
  #45
2012 CLS63
ah ha...........I remember now
those are really pretty nice I gotta tell you
