C218 CLS63, 2011 - 2019
Weistec and Shift S3ctors' Airstrip Attack
Old Oct 7, 2013 | 12:55 AM
freefall's Avatar
2012 C63 Purpose built race car, 2015 CLS 63 S, 2016 GLA45, 2017 GTS
Just wanted to take a moment to thank Weistec for the amazing results I had at this weekends’ Shift S3ctor Airstrip Attack. In the half mile from a dig I trapped 164.59 which I believe was the fastest AMG at the event. My car currently has their upgraded turbos, downpipes, cooling mods and ice tank and I was running on stock rims with Toyo 888s. In addition, at a dyno event I attending a couple of weeks prior, I hit 707/816 in 90 degrees running a mix of California's 91 crap and MS109.
Outside of the amazing car, the track support they provided was second to none hooking me up me with race gas, ice and adjusting my tune throughout the day. Steve, Mike and their crew are not only are great at what they do but are real fun to hang with as well.
I don’t often post these days but with the results I had and the support they provided I just had to share with the community.
IMHO you just can’t go wrong with these guys.
Our goal for the next half mile event will be 170 and I know we can do it.
To Steve, Mike and the Crew…thank you thank you thank you
Old Oct 7, 2013 | 02:26 AM
vdubpower's Avatar
i drive them all, fast and hard
awesome....we need videos
Old Oct 7, 2013 | 08:06 AM
hyperion667's Avatar
2012 CLS63
hot damn that's moving FF
Old Oct 7, 2013 | 09:13 AM
emericr's Avatar
2021 Porsche TTS
Wow, impressive numbers. I assume that is at the wheels. I just talked to them last week and they were also very helpful on the phone with my bogdown and burnout issue and I am not even a customer yet. Awesome guys.
Old Oct 7, 2013 | 01:24 PM
freefall's Avatar
Yep at the wheels and it was 90 degrees out plus most thought the dyno was reading low. I have the file for the dyno sheet but I'm a Mac guy and DynoJet only has the file for PCs. I'll figure it out and get it up soon.
Old Oct 7, 2013 | 02:13 PM
emericr's Avatar
2021 Porsche TTS
What cooling mods do you have? How can you tell it is really making an improvement?
Old Oct 7, 2013 | 02:51 PM
Weistec's Avatar
Former Vendor of MBWorld
Weistec
Hello Emericr, he is running our off the shelf cooling system upgrade. Please see the link below.
http://weistec.com/m157cooling.html
As part of customer support, we data logged many of our customers cars to make sure they were running well and we saw about a 15 degree Celsius drop in temp with our cooling package compared to a stock cooling system, and almost 35 degree Celsius drop in temp with our cooling system when running ice. Please feel free to let us know if you would like more information on this. Thank you!
Weistec Engineering
Old Oct 7, 2013 | 02:55 PM
Faris63's Avatar
'13 CLS63 PP
Hey Jason it was nice meeting you and your car is a beast. The guys from Weistec are very helpful and they take good care of their customers. My car trapped 160MPH with race tune on MS109 but I'm not sure one of the people in event told me because they weren't taking the trap speed at the end of the event my official trap is 159MPH
Old Oct 7, 2013 | 03:29 PM
emericr's Avatar
2021 Porsche TTS
Thanks for the info. I believe MB made a change on their cooling system in 2013 related to splitting the system. Can you expand on how different your system is compared to the new OEM system.
I guess the larger intercooler placed in a better spot would be a major improvement. I am not a track junkie so not interested in filling up my trunk with a tank.
Weistec Engineering
Old Oct 7, 2013 | 07:01 PM
E-SICKTY3's Avatar
'13 CLS63 PP, '16 Huracan , '11 RR Ghost
Hey Faris, good to see you at Shift S3ctor. Your car was definitely fast! They weren't taking the trap speed at the end because the far lane trap speed recorder was broken.
I was kinda disappointed with how my car runs -- I think I'm only good on the first two runs, then it got worse.. I only trap 144.96 best and Eric (xtyper) was trapping 156mph I believe, he is fast too. I seriously don't know what is wrong with the tune or is it my car -- Steve was telling me intake temperature was too high.
Old Oct 7, 2013 | 07:15 PM
Weistec's Avatar
Weistec
You are correct, there was an update in mid 2012 models which split the system however these cars run a heat exchanger between the air conditioning condenser and main engine radiator. There is no clear air flow path which makes it very difficult to dissipate any heat. Furthermore, the trunk tank works as a reservoir which splits the system and adds about 5-6 gallons of fluid capacity. There are some minor hardware changes between the newly revised MB setup and the older non-split setup that is included in the package to cover the entire spectrum.
The trunk tank is mounted in the spare tire well and does not take up trunk space. It is also great to put some weight behind the tires as well. You can add water once and forget about it. Those who track the car can add if needed.
Old Oct 7, 2013 | 07:18 PM
Weistec's Avatar
Weistec
Hi E-SICKTY3 it was great to finally meet you at the event. You have a very nice CLS! We were very limited on time and tools at the event to take care of the issue however we would be happy to take a look at it if you are in the area. Please let us know and we will definitely take care of you! It could be a bad factory intercooler water pump which is causing the temperatures to rise. Thank you!
Weistec Engineering
Old Oct 9, 2013 | 10:14 PM
E-SICKTY3's Avatar
Weistec Engineering
Thanks!
This is a bit vague. When I was there on Saturday Steve told me you guys have all the tools needed to make a change or fix the issue -- now you are telling me you have limited tools. Seriously, this issue starts to irritate me. You expect me to drive another 380miles just for this issue? I drove to your facility to get it tuned at first, then sent back the ECU to get the issue fixed but I still get the same result on the dyno sheet. You guys should have fixed the issue the 2nd time or at Shift S3ctor.
Old Oct 10, 2013 | 08:11 AM
2012 CLS63
Old Oct 10, 2013 | 11:25 AM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
Congrats!!!
Old Oct 11, 2013 | 02:56 PM
vdubpower's Avatar
When are the videos coming out
Old Oct 12, 2013 | 04:08 AM
will175's Avatar
Wish I made it out to the event..Heard it was a good one. And your 63's are moving. Couple of my friends were out there with there TT Lambos.
Hope you had fun Faris. Thanks bro..
Aloha,
Will
Old Oct 12, 2013 | 05:32 AM
Faris63's Avatar
'13 CLS63 PP
Aloha,
Will
It was really a nice event but the heat was killing us and killing our cars lol
Hope to see you soon Will
