C218 CLS63, 2011 - 2019
Start up noise
Old Oct 8, 2013 | 12:50 AM
abhatti55's Avatar
'19 G63 Ed 1,'18 M5, '16 G63,'12 458 , '11 E63, Brabus SL55-K8, '10 S63, '94 E500 "Wolf", '91 560SEC
Start up noise
I am noticing a noise similar to lifters tapping on cold start, but it isn't the lifters. That is closest way I can describe it. It disappears after a few seconds and only returns when the car has been sitting an hour or so.
Is anybody else with this engine experience anything similar?
Old Oct 8, 2013 | 01:06 AM
Faris63's Avatar
'13 CLS63 PP
It's the fuel injection pump
Old Oct 8, 2013 | 11:32 AM
abhatti55's Avatar
So is it normal, or something I need to get checked out?
Old Oct 8, 2013 | 12:41 PM
mb techman's Avatar
CLA45
Old Oct 8, 2013 | 01:19 PM
Faris63's Avatar
'13 CLS63 PP
it's normal
Old Oct 8, 2013 | 01:53 PM
mb techman's Avatar
CLA45
Old Oct 8, 2013 | 01:54 PM
abhatti55's Avatar
Originally Posted by mb techman
is it a rattling noise almost like its starved for oil? then quiets down about 3 seconds after?
if so, look at my threads for the 276 engine.
No it's definitely not an internal engine noise. It is like Faris63 described noisy fuel injectors or the fuel pump trying to prime up. I'm new to the engine platform and wasn't sure if it was a normal occurrence or not.
The noise can be embarrassing coming from a car like this, but if it is normal I can live with it.
Old Oct 8, 2013 | 01:56 PM
mb techman's Avatar
CLA45
Old Oct 8, 2013 | 02:01 PM
abhatti55's Avatar
guarantee its what i posted. the fuel pump doesnt get noisy then quiet.
what you here is the chain slap because the chain tensioners have bled down, and are being pressurized with oil.
Thank you I read the bulletin you posted, after reading it this makes sense. How can I find my engine number to see if it is within the range of affected engines?
Old Oct 8, 2013 | 02:20 PM
Faris63's Avatar
'13 CLS63 PP
not normal. applies to the 157 engine as well: https://mbworld.org/forums/c-class-w...ine-noise.html
look for the link to the .pdf with the technical bulletin.
I don't know about other cars but it's normal for M157 engines to make this fuel injection pump noise for only the first 15 sec when the engine is cold. It does it even when the engine is warm sometimes
Old Oct 8, 2013 | 02:40 PM
mb techman's Avatar
CLA45
Old Oct 8, 2013 | 02:47 PM
Faris63's Avatar
'13 CLS63 PP
That's true it difficult to diagnose it from someone who knows
I saw the pdf file with parts that fix this problem but does these parts require engine to be removed ?
Old Oct 8, 2013 | 02:53 PM
mb techman's Avatar
CLA45
Old Oct 9, 2013 | 03:36 PM
E-SICKTY3's Avatar
'13 CLS63 PP, '16 Huracan , '11 RR Ghost
I got the same noise during start up. At first, technician told me it was normal but now I will have it checked.
Thanks for the PDF too.
Old Oct 28, 2013 | 12:46 PM
abhatti55's Avatar
Thanks to mb techman for posting the bulletin. My dealer replaced the tensioners and check valves. No more start up noise. 2012 owners, I would recommend seeing if your engine number falls within the range for affected engines.
Old Oct 28, 2013 | 04:14 PM
Steinhart's Avatar
2018 S 650, 2014 SL 550, 2017 911 TTS Cab, '13 F458 Spider
where can I find my engine number?
Old Oct 29, 2013 | 11:12 AM
mb techman's Avatar
CLA45
Old Oct 30, 2013 | 03:25 AM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
does it harm the engine on the long run if it was not fixed ? or is it just the noise !!!
Old Oct 30, 2013 | 11:54 AM
abhatti55's Avatar
You can get the data card from Star EPC net. Or get your service advisor to run the VIN.
Old Dec 3, 2013 | 06:57 PM
mb techman's Avatar
CLA45
Old Dec 3, 2013 | 06:58 PM
mb techman's Avatar
CLA45
as of right now, its just noise, but who knows what the long term can bring
Old Dec 3, 2013 | 08:01 PM
vdubpower's Avatar
i drive them all, fast and hard
can someone post audio of the "noise"
my car has always made a ticking sound and ive been told that is normal
Old Dec 3, 2013 | 08:21 PM
mb techman's Avatar
CLA45
Old Dec 3, 2013 | 08:32 PM
mb techman's Avatar
CLA45
Old Dec 3, 2013 | 09:57 PM
abhatti55's Avatar
let me know if this works:
http://vocaroo.com/i/s1ghkP3NKSP5
rattle noise up to :04 seconds in
Mine was doing the exact the same thing. Noise free since the updated tensioners.
