Pre-Mod Dyno Results
Anyway, out of 3 runs my best was 443hp and 446 ft/lbs. They said my first run of 430hp was due to holding back a tad on the rpms and the car being hot from just bringing it in. The guys working there seemed very knowledgeable and were impressed by the loss % to the wheels. All and all it was a great experience and I can't wait until my after mod dyno next week. I will keep all posted. I'll also post the pics of the dyno shop and process when I figure out how to DL the pics.
This says alot. It is probably as I suspected, M-B is understating the true HP/TQ of that motor. With an 18% drivetrain loss (which is typical in RWD cars) your cars is really putting out about 520hp at the flywheel.
I dynoed my SL600 before getting the RennTech Upgrade and it put out 469hp at the rear wheels or 553hp at the flywheel. This makes perfect sense because M-B put the same exact powertrain in the Maybach and rated that at 550hp.
either you had a especially sweet engine or MB detuned our engine on paper.
I think I read somewhere that the engine in the E55 puts out less hp than a SL because of a more restrictive intake and longer exhaust and our car is suppose to be the same as the E55.
When we dyoned my car, it was put in "dyno mode" to avoid any computer interference.
What it doesn't show is whether these numbers are corrected or not. The graph usually displays the correction factor used std, sae, and uncorrected. It shows cf 1.00 on the bottom but doesn't show method.
im planning to dyno mine as well to get a baseline number before modding
Be careful with this. You have no computer angels on your shoulder when driving (ESP/ABS)
In 3rd gear your power will be inflated, but your torque will be deflated.
Based on your graph above, I would guess that if you ran in 4th you would probably be at 425 - 430rwhp, 470 - 480rwtq. That is one healthy motor you have! Congrats!
rflow306 made a few points for you to consider next time you dyno. Find out if they are using corrected #'s and if they are make sure they are using SAE correction factor.
Enjoy that beast of yours!
The dyno jet calculates the horsepower and then determines the torque value only when an rpm signal is present. If you get fluctuations from your rpm pick-up you will get incorrect torque values .
I'm pretty sure all three pulls were in 3rd gear but I do know these were corrected numbers. The uncorrected numbers were a lot higher and the guy that ran before me asked for the uncorrected numbers sheet so he could boast higher HP when selling the car.
That "Dyno Mode" post was interesting. When I go for my "after mod" dyno I will have them try that on a few extra runs. To see my real gains I will have to use the exact method as before though. Here is their info if anyone is in the area and wants a dyno. Great place and great people.
The Dyno Store 10040 #E Canoga Blvd, Chatsworth, Ca 91311 (818) 576-9373
Or just take the numbers you get from rwhp and divide by .80 (which we assume will be the transmission loss on an automatic Mercedes, which is optimistic for the engine dyno).
Say you have 448rwhp.
448 / .8 = 560.
That means the engine is making 560hp (theoretical figures) if we consider that the transmission creates a 20% hp loss due to heat, friction, and whatever else.
Say we were really proud of our transmission and claim a 15% driveline loss. So lets do the equation again.
448rwhp (which we got from the dyno) / .85 = 527.
448 / .8 = 560.
