Air suspension
Old Mar 4, 2006 | 08:11 PM
Benzrider's Avatar
Air suspension
When you lower the car using the air suspenion button you can tell the difference and how many inches does it lower? Also does anyone have pics of it lowered and regular? Thank you
Old Mar 5, 2006 | 12:00 AM
vrracr's Avatar
CLS55
you can only raise it and yes, you can feel it if you have your foot out the door touching the floor or if you're focused on an object out the window.
Old Mar 5, 2006 | 12:49 AM
api3's Avatar
if u raised the car, and never reset it back to the regular height, wil it stay raised next time u start the car? or will it start in regular height once u restart the car. thx
Old Mar 5, 2006 | 12:51 AM
vrracr's Avatar
CLS55
i'm not 100% certain, but i think it lowers back down once you hit a certain speed. i've never had to raise it up...only to see what the button does when i first got the car.
Old Mar 5, 2006 | 07:28 AM
CLS_AMG's Avatar
2006 CLS55, Barolo Red
I believe it lowers back down once you hit 60mph.
Old Mar 5, 2006 | 10:09 AM
api3's Avatar
so if u dont go over 60, it will stay raised even if u restart the car.?
Old Mar 11, 2006 | 02:48 AM
mrademacher's Avatar
S55, ML350
yes
Old Mar 11, 2006 | 09:56 AM
idrive's Avatar
2017 SL63
The car has 3 ride settings. Normal, sport 1, sport 2
Normal = standard height
s1 = drops aprox. 1/2 inch
s2 = dropped 1 inch fron standard height (approx)
to raise the car.... separate button/adjustment. Car raises about 2 inches.
This setting was just meant to go over big speed bumps, get out of driveway with a big curb/gutter. (slow speed) Not meant for travel.
Old Mar 11, 2006 | 12:40 PM
dudu's Avatar
cls55 arriving. 645 hamann kit, sl500 opera kit
can u go sport2...and also press on the raised the car bottom ... will that raise the car or lower...hehe
Old Mar 11, 2006 | 04:36 PM
idrive's Avatar
2017 SL63
Yes, I drive the car in sport 2 most of the time. When I come to a spot I think the front end might scrape (mostly coming out of a driveway) I push the raise button, go over the bump, then push it to return to my designated ride setting.
Old Mar 11, 2006 | 07:39 PM
dudu's Avatar
thx man
will the ride height be the same when u press sport 2 with raise button VS just raise buttom...
just got a little confused when u said the sport2 will also lower ur car...
Old Mar 11, 2006 | 09:40 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
i thought sport 1 and sport 2 modes just made the suspension stiffer.
are u sure it adjusts height as well?
