Recall cls 63
Old Mar 30, 2007 | 01:46 AM
rarfinancial's Avatar
CLS63
Recall cls 63
O.k took my 63 in for the "A" service. The service writer said there is a v belt recall. I also asked to see the service records. Well looks like my car has been in twice before. The tech states that there is excesive oil usage on both visits, once at 4900 mile and again at 7600 miles, now with 9100 miles I have the same problem with the oil being used. I told them, three times in for oil usage sound like a major problem. As always the techs state that the 63's will use one quart of oil every 1000 mile.. WTF? I own a used car dealership and if I sold a car that used a quart of oil every 1000 miles a full refund would be in hand. I smell a LEMON LAW brewing.. any in put ?
Old Mar 30, 2007 | 02:37 AM
Kevin M.'s Avatar
CLS 55
Sounds very odd, and now way a car should burn a quart evey 1k miles.
I'd ask to speak to a the service rep for that area.
Old Mar 30, 2007 | 03:13 AM
MB Fanatic's Avatar
4 wheels
Actually its normal for some cars to burn up to a quart of oil every 1000 miles. My 04 TL acutally did as did the E55K.
Old Mar 30, 2007 | 03:17 AM
Kevin M.'s Avatar
CLS 55
So you have to buy a case of oil for 12k miles of driving? thats just wrong.
Old Mar 30, 2007 | 03:30 AM
amalamud's Avatar
CLS55 06 (K4, LSD), Range Rover Sport 06, Bentley Flying Spur 07
My friend has a cayenne turbo with the same problem. I don't understand why a brand new car should burn up any oil?
Old Mar 30, 2007 | 03:35 AM
CynCarvin32's Avatar
Mercedes Benz
Honestly the car does use some oil and some are worse than others. I got a E350 for 350 a month to drive around and that car used oil for the first 5k miles until the seals all seated correctly. If I let the car sit for say 2 hrs after driving it and then go to re-start it, there was a plume of blue smoke everywhere. The problem went away and my shop foreman (a friend as well) said drive it hard as hell and the motor will seal up and the smoke/oil usage will go away. I have not seen it happen for quite some time.
So maybe you just need to beat on the car a bit to make it seal. The shop foreman did say that the ultra hard metal used to line the pistons in the new generation of engines takes quite some time to break in and seal. There is a TSB for this issue on the new V6 and V8's. Maybe the AMG motor is similar.
If compression is spot on and the car makes power I think its just a matter of time until it goes away.
Old Mar 30, 2007 | 03:59 AM
transferred's Avatar
08 S65, 06 M3 CS(stick), 02 BMW X5 4.6iS, 07 R1 Raven, 08 F-450 4x4, 08 CooperS JCW
May wanna change your avatar- 6.2 is the capacity.
Old Mar 30, 2007 | 10:23 AM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
My M5 burns at least that. High revs break down oil like crazy. Plus it uses a very special lightweight oil that doesn't like the abuse. What kind of oil are you putting in that thing? Mine takes 10w60.
Old Mar 30, 2007 | 10:31 AM
CLS63
thanks for the wisdom "tranferred" but what does that have to do with this topic but thanks any how.. Guys, thanks for the helpful input. I will keep an I on the oil. The car has 9100 mile on it. I would think it is broken in. So looks like I will beat on the car for the next 1000 mile to see how it does...
Old Mar 30, 2007 | 07:43 PM
Now, now...No offense intended. At least it's fixed.
Old Mar 30, 2007 | 08:15 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Off Topic
If you truly have 1969 Porsche 911 RS you would know that every 500 miles you must add 1 quart of oil. That is what the factory clearly states is normal in the owners manual. Aditionaly that is for an engine that is broken in.
My Berg-spyder 2.2 twin plug, slide throttles, MFI will easly burn 1 quart in one round trip Avon CO. to Aspen via Leadville @7000 rpm.
Old Mar 30, 2007 | 08:39 PM
Get a load on that engine
So that is why you wanted to trade your 07 for a new 07
You just have some glazed cylinders
We run in our aircraft engines @ 90% load, real hard to do in an E 63 in the USA.
Reprint from Textron Lycoming
For those who still think that running the engine hard during break-in falls into the category of cruel and unusual punishment, there is one more argument for high power settings during engine break-in. The use of low power settings does not expand the piston rings enough, and a film of oil is left on the cylinder walls. The high temperatures in the combustion chamber will oxidize this oil film so that it creates a condition commonly known as glazing of the cylinder walls. When this happens, the ring break-in process stops, and excessive oil consumption frequently occurs. The bad news is that extensive glazing can only be corrected by removing the cylinders and re honing the walls. An expense that can be avoided by proper break in procedures.
Now I don't know if our rings are pressure back or not, but if they are you must load the engine to make them seal/seat.
Old Mar 31, 2007 | 02:07 AM
MB Fanatic's Avatar
4 wheels
The 63's have a special silicon coating that should prevent glazing of the cylinder walls. But who knows.
Old Mar 31, 2007 | 08:23 AM
All V8 Mercedes for the past 30 years have had a "special silicon coating ".
I don't follow your reasoning that that would prevent glazing, if anything it helps to promote it. I am not trying to be confrontational. I am sure that larger Mercedes dealerships have bore scopes to assess cylinder wall damage. That is the only way to tell what is going on plain and simple.
Old Mar 31, 2007 | 02:11 PM
MB Fanatic's Avatar
4 wheels
http://www.worldcarfans.com/news.cfm...-coupe-and-amg
This is brand new technology in the 63 engine my friend.
Unique process for cylinder wall coating
The engine block and cylinder heads are of cast aluminium-silicon alloys (AlSi7 and AlSi17) which represent the state of the art in terms of weight, thermal and mechanical resistance and long-term strength. The engine specialists at Mercedes-AMG use a particularly advanced process for the eight cylinder walls to produce a tribologically optimal surface, namely a coating applied by twin wire arc spraying (TWAS). The advantages of this technology are extremely low friction and wear accompanied by outstanding long-term durability. A considerably harder surface is achieved compared to conventionally coated cylinder walls. In fact the cylinder walls of the new AMG V8 engine are twice as hard as conventional cast iron liners – a quantum leap for engine specialists.
No other series-production engine apart from the new AMG 6.3-litre V8 unit can boast such sophisticated technology - which means that once again, Mercedes-AMG has underlined its pioneering role in the development and production of innovative high-performance engines.
During the TWAS process, two metallic wires and an atomising gas are brought together in a coating unit. Passing a high voltage through the tips of the wires breaks the gas molecules down to form a plasma, and the wire tips begin to melt. The atomising gas removes molten metal from the wire tips and sprays these particles onto the cylinder walls to be coated, where they solidify. This is preceded by a high-pressure water jet which roughens the cylinder walls so that the individual sprayed particles adhere to the surface during the TWAS coating process.
The cylinder walls are then honed to achieve a perfect surface structure. During this process the micro-pores in the sprayed coating are partially exposed, which enables them to retain oil when the engine is running and ensure tribologically favourable lubrication of the pistons and piston rings.
This trailblazing process was developed in close collaboration between the DaimlerChrysler process engineering department and Mercedes-AMG, and has been brought to series production maturity for the first time in the AMG V8 engine.
Old Mar 31, 2007 | 04:41 PM
Thank you for taking the time to post the article. Mercedes has been running aluminum bores that have specialized coatings for years. Now if you can explain how this prevents glazing, I am all ears.
What the article states 1.>>>"micro-pores in the sprayed coating are partially exposed, which enables them to retain oil "<<< this condition helps promote glazing. 2. >>>"The advantages of this technology are extremely low friction and wear "<<< the improved coating provides low friction, this too is conducive to glazing, and further prevents piston rings to run in.
Additionally the oil that is retained on and in the cylinder wall will oxidize on power stroke this is the first condition of glazing.
Once this condition starts the piston rings may never seat/seal properly. The engine will still make power, idle smooth and seem to be problem free. The reality is that oil consumption will be excessive as will be the contamination of that oil, (black oil) you may also experience larger amounts of crankcases blowby and fouling of the cats.
Hey this is just an educated guess seems more than one 63 is using more oil than any of us expected. If you have a better explanation, have at it. Further more if you have a 63 time to use that dip stick every 100 miles and start your log.
Old Mar 31, 2007 | 04:58 PM
TREZ63's Avatar
2010 RRS ; BMW K1200R; 14 E350 ; 14 RRS on order
I just added a quart to mine at ~ 4000 miles and it had an oil change at 1200. So somehow between 1200 and 4000 I burnt 1 quart. And let me tell you, I didn't break this engine in at all. I drove it like an AMG from day one.
Another thing to consider is that the W0-40 oil is a high performance oil ... don't know what that means exactly but it might be a factor.
Personally I don't mind having to add some oil from time to time to the car. I like being in the habit of checking it anyway.
Old Mar 31, 2007 | 05:06 PM
juicee63's Avatar
2011 twin turboed prius
I finally got the oil light but I drove 3000 miles prior and I drive like I am racing, hitting the apex on all my turns :-).. I am positive the higher revolution will eat mas oil. So changing or adding every 3k miles seems like a no brainer. Thanks for the information on the coating and sealing processes. Please do not chime in and say "processes is not a word"
Old Mar 31, 2007 | 05:44 PM
Trezaei, One quart for 3000 miles is indicative of a healthy new engine. I think the fact you did not baby the 63 around may prove to be the most correct way to run in a 63. The W0-40 you are right it is a factor, I would have to check with the SD crew, but I think tequila is also w0-40
Sounds like this 63 is going to be one bullet proof engine, as hard as it is to break in.
Old Apr 1, 2007 | 11:05 PM
CLS63AMGGUY's Avatar
'07 CLS63 AMG, '08 S550, '09 GL450 w/appearance pkg., ('06 BMW '04 M3, '01 Boxster S - ALL SOLD)
I had oil problems...burned quite a bit...they did some fixing and I haven't had any problems since...knock on wood...said it was due to the fact that the engine was hand built and things just needed to be tightened a bit more...
