mounting AMG license plate frame
so we have
rear decklid--->steel frame backing--->license plate--->amg frame
I do recall the steel backing screws are narrower than the license plate screws. I think the backing also has some sort of protector so that you dont scratch the car by screwing into the rear trunklid. i can take a photo if necessary.
The bolts for the frame are actually wider than the bolts for the plate.
hope this helps. The vin number is on the sticker on the bracket, dont understand why.
Just wondering , do the euro guys have a similar setup just wider to accomodate their plate?
-J
Did the screws you used to attach the plate to the bracket fit through those white washers that came with the plate frame? (the washers that the decorative caps fit over)
Thanks again!
good luck
