TPMS question for 06 CLS55 AMG?
2006 CLS55 AMG; 2006 Infiniti FX45;
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Hey guys. I'm getting conflicting reports as to whether the 06 cls55 amg has TPMS or some other system it uses to calculate loss of tire pressure. Everyone I've spoken to and have also read searching through the forum, seems to give the same conflicting reports.
I had a flat the other day. When roadside assistance came out to pump up the spair and change my tire, I didn't see anything that would lead me to believe it actually has tpms. The Mercedes technician didn't seem to even know. He just pull the tire off and installed the donught.
I need help on this this. Can someone explain to me what system we have and if I should have any problem installing new wheels and tires once it comes in? Thank you in advance.
'10 Tesla Roadster, '06 AMG CLS 55; '00 SVT F-150
CLS55 has a passive system vs CLS63 which has TPMS
quoted from an old thread...
the 55's (what I have also) is a passive system... I've heard that a calculation is done by the on-board computer. An estimate is made based on comparing the standard rate of rotation of the wheels vs the rate it rotates with less air pressure...
I can't cite the exact physics behind it, but if one tire has less pressure, it will have more rolling resistance, a smaller radius, and diameter.
The system is not very accurate, but has been able to warn me when there has been significant changes in pressure, but not minor ones.
meanwhile, the 63's have actual physical tire pressure sensors, meaning you don't have to be in motion for the computer to calculate whether you have a flat/less air in the tire(s)...
hope that helps.
- Ed
hope that helps.
- Ed
if you look at your owner's Manual you'll see the TPMS is, depending on markets, available as an option. ther eis also explained how it works.
my car is at the Service in this moment .. and there are trying to retrofit the complete TPMS (or RDK in german) system: it is expensive indeed !
.. you need a control unit + 4 wheel sensors + 4 antennas + .. a lot of cables
.. can't wait
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
.. can't wait
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
TPMS is an option.
You have a wireless sensor in each wheel, and an antenna in each wheel arch (you should be able to see this under the arch)
If you have the TPMS option, it will be one of the pages in the dash display and will show you the actual pressure in each wheel.
As standard, the car also has tyre deflate monitor. This basically warns you if there is a sudden loss of pressure (blow out) in a tyre. This uses the ABS sensors to monitor the rotation of the wheel compared to others tyres.
You wont see any info related to this system in the display unless a tyre fails.
Amit
Amit
TPMS is an option.
Amit
Amit
Thanks to all.
This is not entirely true... The passive system has been able to warn me when there is low pressure.
While I prefer an actual TPMS as in my other cars, the CLS55, depending on the region you have your car, were passive by default. The US was late in mandating that all cars have TPMS, unlike other parts of the world.
But to answer your question, yes, you should be able to mount any rim / tire of your choice as long as the overall diameter of the tire is the same.
I have a 2006 CLS55 and mine does have TPMS with sensors and my dash shows individual tire pressure. I just bought aftermarket wheels and everywhere I go to buy sensors, the people tell me my car doesnt have sensors in it and its a passive system. Yet I replaced the rear wheels and now I get a message saying sensors missing. Do some 55's have sensors and others don't?
'06 cls 55 amg, '03 Range Rover HSE, 88 Firebird Formula
I'm having the same confusing issue. My 55 only let's me know that the tire pressure is low but doesn't let me know which tire is low. I guess this means I have the passive TPMS? I'm about to get aftermarket wheels and was going to remove the factory TPMS sensors but I'll probably not do this now.
As someone mentioned, if the vehicle has it, it will be accessable via the menus, and shows an image of the vehicle with the tire pressure for each tire shown next to its relative position.
So now comes the next question: does anyone here have the TPMS on a CLS55 which does not have the 030 package?
Yes. TPMS was listed as option code 475, cost $410, and was, according to the ordering guide I've got, available only with the 030 AMG Performance Package.
i didn't have as stock
but NOW I HAVE IT
not an easy nor cheap retrofit, thou
loving it ...
I didn't imagine that pressure at 2.4bar when parked in the morning could rise to 2.7 just after one km !
![](http://img393.imageshack.us/img393/7122/pressuremonitoringtpmsrpy6.jpg)
06 CLS55 AMG
better you first take off existing weights
this TPMS system is really funny
... I played trying to obtain a perfect pressure match, deflating or inflating each wheel .. and it immediately shows you the new pressure .. then you store it and the system warns only after taking into account for many parameters: external temp, load on the car, speed
I usually never pay due attention to tire pressure ... my Bro always ask me "did you check tire pressure?"
.. now I can finally say YES !
it's definitely a great thing.
So, how much does a system like this cost? Since I don't have the TPMS for each individual tire would I have any problems with getting aftermarket wheels? Would I constantly get the low pressure warning?
209/W210 Estate /W211 modded by MBENZNL
it requires four sensors/antennas/wire harness/control unit and LOTS of labor
as most of the inside of the car must be removed to run the wire harness
because it goes to every corner of the vehicle
With Basic TPMs it uses the ABS wheel speed signal to locate the low tire
it does not use a sensor in side the wheel..so you can change rims without any changes
it does not use a sensor in side the wheel..so you can change rims without any changes[/QUOTE]
Well thanks and I hope everything turns out ok with my new wheels. Thanks
Had to wait more than one month for the dealer to get the coding
I think not much less 2k euro + expences if you have to go far away
... but you can find ways to economise
