Tire Wear with 20's
Wanted to get some comparison data...have 20 inch Maya's with Falken 452's...wore the inside edge on the fronts badly at 13K mi...am replacing the rears now too since the inside is almost gone too...
Is this what I should expect?...car is lowered but otherwise stock...tracks straight so I don't think the alignment is off but to have them wear so unevenly is odd to me...camber?...
Your thoughts?...and recommendations to increase tire life...
thx...Mike
1) Should rotate tires right when you start seeing inner wear
2) Keep tires at the right tire pressure
3) Don't slam your car
I've heard of a cambet kit, not sure if it works though.... please chime in if anybody had heard of any camber adjustments on these cars.
??did you get a alignment after you lowered it ??? This is only for the fronts for the rear there are som tricks to get the alignment in spec just find a good alingment shop in your area
I have got new rubber on as of today all the way around and am going on Saturday to a local alignment shop that allegedly knows about lowered MBZ...recommended by a local MBZ tuner/wheel shop here in SoCal...
I'll ask about the bolts and report here early next week...I don't have any unrealistic expectations about wear, but would like to get more than 13K...
I assume I can walk into a dealer and they'll know what I am talking about at the parts counter?...
thx everyone...
Mike
I'll let you know after the work is done this weekend...
Mike
I got under the car too and what the tech said and I saw with my own eyes is there is NO adjustment for camber on these cars...now the decision is to eat the tires quickly, rotate left to right for max wear and live with it...or,
raise it back up to stock height...which could give more miles...Unless I am missing something, I cannot find a camber kit for this car...anyone have any other ideas???
thx...Mike
That largely is your problem there...the vehicle SHOULD BE aligned each time the ride height is changed. If you have a lowering module than it should be aligned at the ride height you choose to drive the car at the majority of the time. Otherwise you can have the same experience on a regular basis if you don't correct it.
Find out what the camber and toe specs for the car actually are and then you will actually know if you need to get camber bolts or not. My guess is that the rear will probably need them, but lets just wait for vindication on that subject. Good luck.
People think that any offset that prevents rubbing is ok, but that's not the point.
Make sure your wheels are close to the factory offset or you'll never get your steering geometry dialed in.
The AMG recommended 19s are 8.5 X 19 ET 25 front and 10 X 19 ET 28. The offsets are identical for AMG 18 inch wheels and would be the best estimate for 20s. Your rear wheels are pretty wide. What size tires are you running? The biggest I've seen are 255/30-20 on 20X9 front and 295/25-20 on 20X10 or 20X10.5. Are you running 20 series?
There is no camber adjustment on the CLS...I am told by the tech and verified today with the service advisor at FJ Mercedes that there is no camber adjustment for the front...and couldn't see where it would be in the back...
Renntech has a camber/ball joint kit for like $1500 for each kit...makes no sense with the price of the tires...
Again, if someone can show me how there is a camber adjustment with a bolt holding the bushing through the frame, I'll be happy to eat humble pie...I just don't see it...
As far as the offset, it might have some small contribution...but the major issue is camber...I am off -3/4% in the front...and not too bad in the back...Toe was right on and caster was too...
I am frustrated...
