Whats the different between 172mm and 180mm pulleys
Old Mar 30, 2010 | 01:08 PM
has123's Avatar
merc e55k amg
e55 pulleys
Originally Posted by dyno
the bigger it is, the quicker you get overheating issues you then have to cope somehow ... except you need it only for a one fourth mile run or you live in a very cold area
you can find a lot on this subject by using the search function. you will also find a naive table showing a supposed relation between pulley dia and HP increase
about two years ago the question was deeply discussed and the consensus, at that time, was for a pulley close to 170mm as the best option .
...today it's moving forward
btw,
i have fitted a 172mm pulley,sports cat,k&n filters. and my car has gone slower,any suggestions
Old Mar 30, 2010 | 06:35 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
perhaps your cooling pump is not working?
Old Mar 30, 2010 | 06:59 PM
beauphus's Avatar
CLS55 & CL CK60
is it tuned?
Old Mar 31, 2010 | 03:42 PM
TopEndS62's Avatar
2005 BLK/BLK E-Double Nickel.
Originally Posted by beauphus
is it tuned?
+1 on dat question!!!!
Old Apr 7, 2010 | 03:30 PM
has123's Avatar
merc e55k amg
e55 amg
is it tuned?
i have recently tuned it, it is better showing max 582hp on dyno.but now @ times it goes in to a limp mode for a couple of secs when i set off & then powers up & then @ times it doesnt power up @ all untill i release the gas & power up slow.i know its not the ESP becouse that normally flashes, dionostics have been checked no foults shown.is it possibly over boosting.thanks
Old Dec 9, 2010 | 11:06 PM
Mantooth's Avatar
2004 E55 AMG
I know this is a really old thread, but if you see this, and haven't figured it out yet(I'm sure you have), replaced your I/C pump.
