cls55 -what is with the oil leaks on valve covers
Old Aug 8, 2009 | 12:07 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
I've been looking at a few 2006 CLS55 2 out of 4 has oil covered valve covers and the igniter coils were covered with oil..
One of them at 22k miles even have a power steering leak.. Is this a major repair?
my 2000 ml55 and 2002 s430 are bone dry underhood no leaks at all. I expect the same with the supercharged engine.
Old Aug 8, 2009 | 12:32 PM
markabcls55's Avatar
CLS55 AMG
I don't know the history of the 55's that well...
But mine had the covers resealed under warranty @21k miles, and had the coil packs inspected during the repair.
They use a sealer, instead of a gasket. Perhaps there is expansion issues or sealer degradation over time.
Power Steering
Old Aug 8, 2009 | 12:59 PM
blahuh's Avatar
1998 C43
All 112's and 113's have valve cover leak issues. Usually not a big deal just get it taken care of sooner than later
Old Aug 8, 2009 | 09:50 PM
nJuDunno's Avatar
Mine was just in for 40k service and had valve cover leaks fixed with new gasket and sealer. Also my power steering fluid was leaking from the resovoir o-ring. Both were fixed under warranty
Old Aug 23, 2009 | 01:05 AM
Kevin M.'s Avatar
CLS 55
Just noticed mine leaking today, 11k miles.
Old Aug 23, 2009 | 09:49 AM
Quadcammer's Avatar
96 and 08 911 turbos
Probably some sloppy application of the gasket maker.
I had a leak, removed breather cover, cleaned the sealing area, and put new gasket maker down, and bolted back up.
Cost about $8 and took maybe an hour (most of which is spent cleaning the old sealant off).
Old Aug 24, 2009 | 11:29 AM
khelawanb's Avatar
2006 CLS500 with 55 AMG motor, 2008 Infiniti G35, 2000 Plymouth Grand Voyager
Mine leaked after a year of owning the car. Fixed by the dealer, and no problems since it was fixed.
Old Jan 17, 2012 | 02:44 PM
ER1's Avatar
ER1
Tesla Model S P85D
Sorry to resurrect the old thread...
My car (CLS 55 AMG 2006, 55k miles) was just in the annual maintenance and the serviceman said that my valve cover gasket / rocker cover gasket is leaking oil in the engine. I have the German Mercedes-Benz used car warranty (Gebrauchtwagen Garantie). Do you think this is covered by the warranty? Is this a serious problem and what kind of symptoms does this usually cause? I haven't really noticed any major problems with the car. What might have caused the leak and is this problem common? I was quoted that repair costs would be around 600 USD.
