Center Channel Speaker Toasted...
Old Dec 29, 2009 | 11:44 PM
DucatiGuy's Avatar
06 CLS55 AMG
Center speaker just started crackling away this afternoon. I searched the forum and although I found some info regrading it, nothing really solid in terms of anyone upgrading it...
With that said, has anyone ventured into swapping their center channel out? I found one post on another forum talking about a 2.5" replacement, while another referred to a possible 4" replacement...
Any advice, info or suggestions would be greatly appreciated!
Old Dec 30, 2009 | 12:44 AM
Cyberous's Avatar
S 63
Are you just looking for upgrade? I called Crutchfield when mine went out and they said they didn't have any direct replacements.
You can find the OEM one here http://www.primepartssuperstore.com
Part "Inst pnl speaker " $31.57
Don
Old Dec 30, 2009 | 04:52 AM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
the stock is about 75mm, but mounting depth is small: about 4cm
just, don't put any midrange because this center speaker is a "Full range" even if its real range is obviously limited by its size ..
I found this good replacement option HL70 by Hertz/Audison
... me its not enough, so we are trying to fit a 4" woofer + separate tweeter
but its not easy and this is why we need now remove the whole dash
Old Dec 30, 2009 | 10:02 AM
DucatiGuy's Avatar
06 CLS55 AMG
Good stuff! Hey Dyno, how did you go about getting to the center channel speaker? Does the grill just pop off?
EDIT: Got it, it popped right out... Time to do some shopping...
Old Dec 30, 2009 | 12:57 PM
dyno's Avatar
yes, just pull up
after searching a lot I think that Hertz full range 200- 14000Hz, 100Watt is the best option you can find because there's really no additional room available
.. and performancewise no comparison with the stock thing
... should you need to compliment the upgrade with tweeters from AMG E02
option
, maybe I can give you mines
Old Dec 31, 2009 | 10:34 AM
Dogshine's Avatar
CLS55
Is this a direct swap? Does this speaker need more power driving it or will it sound good with the stock system?
Old Dec 31, 2009 | 05:21 PM
dyno's Avatar
no prob for stock power to drive it
... you could have that problem only when replacing a big aftermarket Sub
we have one but I didn't go in detail because it seemed to me a very easy fit and on the othe rhand I wanted a bigger and stronger bass ..
I'll ask my installer to test fit it for you into the housing in my car till it is open
Old Mar 7, 2010 | 11:55 AM
ThePatriot's Avatar
CLS55 AMG
Thank you for the advice; mine too is doing the crackle thing. Not all the time, though; sometimes if I turn off the audio for a while and then back on later it doesn't do it. I'll try to find a supplier here and fix it your way.
Take Care!
Old Mar 7, 2010 | 12:16 PM
dyno's Avatar
.. adaptation required for that swap are minimal
and the importance of the center channel is higly reputed by audio connosseurs.
let 's know how you like it.
Old Mar 7, 2010 | 02:41 PM
rick2964's Avatar
2006 CLS55
My center is doing the same thing...... Im driving all my Alpine component speakers with an Apline PDX5.... The only speaker I left alone was the center channel. Yes my installer didnt seem to think fancy center channels are a reall necessity. I think I will upgrade tho as now it needs replacement. Thanks for the good info.....
Old Aug 1, 2010 | 01:18 AM
toniboi's Avatar
Cls63 AMG
Hi Rick, do you still have your factory head unit? I am thinking about swapping out all my stock non-logic7 speakers with some Alpine component speakers running on a PDX. Since I wanna keep my factory HU, I am also thinking about an Alpine Imprint sound processor.
Old Aug 18, 2010 | 06:37 AM
ITSEL33's Avatar
CLS 55 AMG
Where can I order this speaker? My center channel is crackling away! You would think this car would come with better speakers.
Old Aug 24, 2010 | 12:50 AM
khelawanb's Avatar
2006 CLS500 with 55 AMG motor, 2008 Infiniti G35, 2000 Plymouth Grand Voyager
I took out my center Chanel to house my Alpine GPS antenna, and mic for my Bluetooth phone adapter.
Anyone want it?
Old Aug 24, 2010 | 11:01 AM
ITSEL33's Avatar
CLS 55 AMG
Anyone want it?
I will take it off your hands if it's not crackling away lol!
Old Aug 24, 2010 | 12:00 PM
khelawanb's Avatar
I think my speaker is in good condition, and I'll give it to you for free if you want it. Take a look at this price list first. This speaker should cost no more than $30, and you would get a warranty on it as well. Check out this price list. The speaker is #6.
Old Aug 24, 2010 | 12:04 PM
khelawanb's Avatar
I always laugh at the price of the command and the cd changer.
Old Aug 24, 2010 | 12:39 PM
ITSEL33's Avatar
CLS 55 AMG
Cool I'll take it thanks. I called Valley Motors and they quoted me $134 for that center channel speaker. What a bunch of crooks
Old Aug 24, 2010 | 01:26 PM
khelawanb's Avatar
I was told that prices fluctuate on these parts but wow! That's a big jump in price. I obtained this part list for both the 55 and 500 back in 06 and the prices are still very similar to the list.
Old Aug 24, 2010 | 03:00 PM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
Heh, make sure that the impedance and sensitivity are the same.
Impedance could be 4 or 6 or 8 ohms. If you take out a 4 ohm and replace
it with the same sensitivity but 6 ohm it will draw less current from the
amp and will give less out put.
Also make sure it's the same sensitivity i.e 1 watt produces 80db.
However if you have ability to adjust it's not so important.
Lastly if your one is 8 ohms and you want to fit a 4 ohm or lower make sure
your amp will drive 4 ohms without cooking itself.
Old Aug 31, 2010 | 09:36 AM
ITSEL33's Avatar
CLS 55 AMG
You got a pm.
Old Sep 6, 2010 | 06:17 PM
rick2964's Avatar
2006 CLS55
I replaced mine with a Kicker. Its pretty small and fit perfectly. The factory center is only glued in the cone area. Between the excessive dash heat and the extra power the cone came apart and began flapping which causes the weird vibration sound.
Old Sep 7, 2010 | 12:38 PM
Dogshine's Avatar
CLS55
which speaker did you use? is there a model number? did it require any modification to fit in? is it the same ohm's?
Old Sep 15, 2010 | 05:06 PM
ITSEL33's Avatar
CLS 55 AMG
Thanks for the speaker. No more crackling!!!! Yes!
Old Sep 19, 2010 | 08:20 PM
khelawanb's Avatar
No problem bro!
Old Sep 19, 2010 | 08:46 PM
Roverron's Avatar
ML63
Is that book from the UK it looks like prices are in pounds.
