Evosport | New Lightweight 2-Piece Front & Rear Rotors for CLS63 AMG
Old Feb 23, 2010 | 12:49 AM
Simon @ evosport's Avatar
PREMIER SPONSOR
UP TO 40-LBS WEIGHT SAVINGS!
Designed as a direct brake rotor replacement for the OE 1-piece or 2-piece (not 390mm 030 PP) brake rotors (front and rear). No modifications are necessary. The Evosport rotors will bolt directly to the car and work with OE AMG brake calipers. Not only will the upgraded multi-piece "floating" rotor design help mitigate brake fade, but are lighter than stock and reduce unsprung weight by up to 40-lbs. on all four corners! Note: 26-lbs weight savings on vehicles equipped with 2-piece OE front rotors. This means better acceleration, braking and cornering. In addition, you get to maintain the AMG calipers without going to a more expensive solution that requires replacing them.
Drilled and slotted to match the OE rotors, hats are lightweight aluminum and hard anodized. And unlike the stock rotors that only vent correct on one side (or have universal venting), the Evosport rotors have a Right and Left application for proper venting of the disc and chaneling of airflow.
Note: Coming soon for CLS63 with 030 Performance Package and 390mm front rotors.
Benefits:
  • Direct bolt-on design requires no modification
  • Works with OE AMG calipers
  • Lightweight design (up to 40-lbs unsprung weight savings over stock! 26-lbs weight savings on vehicles equipped with 2-piece OE front rotors.)
  • Aluminum hat, hard anodized (Black)
  • Better value and cost of ownership over OE! The OE 2-piece 360mm rotor sells for $990 EACH!
  • Unique Left/Right application for proper venting/airflow (unlike OE)
  • Replaceable discs and hardware
  • Better heat dissipation and less brake fade
  • Improved acceleration, braking and cornering with less unsprung weight!
Includes Front and Rear rotors with black anodized hats (Front or Rear pairs can also be purchased separately). For more information or to order, CLICK HERE.
Please feel free to call or email us with any questions.
Anthracite anodized hats shown below. Actual rotors have black anodize:
Evosport 2-Piece Rotor Installed on SL63 AMG (Note: Right-Side Rotor Shown):
Old Feb 23, 2010 | 12:55 AM
dacls63amg's Avatar
2008 CLS63 AMG
How are these lighter than the stock 2 piece front rotors? Lighter materials? Great work by the way!
Old Feb 23, 2010 | 01:04 AM
PREMIER SPONSOR
The Evosport rotor uses much better quality casting on the disc and the hat design is far lighter than OE. Combined savings of 6-lbs per front rotor over the OE 2-piece. And A LOT less expensive!
Old Feb 28, 2010 | 04:48 PM
JADE46's Avatar
Those are hott!! Great job Evosport
Old Mar 1, 2010 | 04:46 PM
Dericious's Avatar
CLS63
I'm confused by your less expensive statement. The OEM totors are $990 each and the evo sport are $1999 for a pair? i'm missing the cost savings on this. what am i missing?
Never mind, i got it. It's $1999 for Front and Rear... now that i can read....
Sweet! will definitely get a set of these when my rotors are ready to be changed!
Old Mar 16, 2010 | 10:09 PM
SSSSE YA's Avatar
2007 CLS 63 030 package 2011 C63 1997 Dodge Viper GTS
Please keep us informed for the 030 Performance Package rotors. TMy CLS is going to need them soon.
Old Mar 17, 2010 | 04:31 PM
PREMIER SPONSOR
The 380mm SL55 030 and CLS55 030 rotors will be next. Then the mighty 390mm SL63 030, CLS63 030 and SL65 rotors following that.
Old Apr 23, 2010 | 07:42 PM
iwannarace99's Avatar
2007 CLS63 Designo Graphite
CLS63 w/ 030
Hurry up with those for the 63 with 030, $5k a pair is crazy!!
Old Apr 23, 2010 | 07:58 PM
PREMIER SPONSOR
That is pretty insane. We're working on it! They should really disclose this information for parts replacement costs when you buy the car.
Old Oct 26, 2010 | 10:22 AM
UDWANIT2's Avatar
2016 E550 Cab & 2011 GL 550 & 09 VROD Muscle & 06 Seadoo Speedster LE .......
I have a big brake upgrade from brembo front r 380 mm 2 piece n rear r 340 mm do u have replacement for this kit....yet...
Old Oct 26, 2010 | 02:11 PM
PREMIER SPONSOR
We will not offer Evosport repalcement rotors for a Brembo kit. You would need to purchase replacement Brembo discs or complete rotors from Brembo, or you can also purchase them from us as we are an authorized Brembo Distributor.
Old Oct 29, 2010 | 01:20 PM
Any word yet?
Any word on replacement parts for the CLS63 with 030? I have maybe 4 or 5 thousand miles until I need to replace them...
Old Oct 29, 2010 | 02:28 PM
Dericious's Avatar
CLS63
anyone using these rotors? curious if they help with the squeal at all and how people like them.
Old Oct 29, 2010 | 03:30 PM
KLR CLS's Avatar
CLS63 PP
Bump for the P030 rotors...Need a set soon too!
Old Oct 31, 2010 | 02:51 PM
PREMIER SPONSOR
them...
No ETA yet. We hope to have a development set in the next couple months.
Do a search- there are a lot of threads and customers running these rotors. Squeal is not a function of the rotors, but the pads.
Old Nov 2, 2010 | 08:58 AM
TraumaDude's Avatar
2019 S63, 2006 CLS 55, 2005 Infiniti QX56, 1994 Softail Springer
How about the CLS 55s out there?
Do you make rotors for the CLS 55?
Old Nov 5, 2010 | 04:59 PM
possible??
does anyone know if it is possible to "downgrade" to the non-P030 brakes and rotors? Seems that might save me about $2500.00 and I am not tracking the car now anyway??
Old Nov 8, 2010 | 02:19 PM
PREMIER SPONSOR
Originally Posted by TraumaDude
Do you make rotors for the CLS55?
Yes, we do offer rotors for all the 55 Kompressor cars.
Yes, you can downgrade but you will need to replace the caliper mounting hardware to accomodate the different size rotor. You should be able to get this from your local dealer.
Old Nov 8, 2010 | 02:36 PM
Roverron's Avatar
ML63
How does it take to get the CLS 55 rotor front and rear?
Old Nov 8, 2010 | 02:56 PM
PREMIER SPONSOR
Not sure I understand the question. I think you're missing some words there Feel free to call us with any questions as well.
Old Nov 21, 2010 | 09:37 PM
mercwhip's Avatar
CLS 55 AMG
Simon. I saw your reply to the question.... are there replacement rotors for the CLS 55? I went to the Evo Sport site. I saw the single piece rotors. Are there 2 peice replacment rotors for the CLS 55?
Old Nov 22, 2010 | 11:47 AM
PREMIER SPONSOR
Yes, we offer 2-piece rotors for the CLS 55. See here:
http://www.evosport.com/product/prod...VO.BRK.M5K.R03
Old Nov 23, 2010 | 06:36 AM
mercwhip's Avatar
CLS 55 AMG
Thanks. Ordering me a set this week.
Old Nov 23, 2010 | 08:54 AM
Roverron's Avatar
ML63
How long does it take to get the CLS 55 rotors front and rear?
Sorry I should have proofed my post.
Old Nov 23, 2010 | 10:57 AM
brad @ evosport's Avatar
PREMIER SPONSOR
None fast enough!
It is usually very quick. However we have had back orders for the last couple months unfortunately. All of those are about ready, so we will be caught up.
Best bet is to ace an order early just to be sure.
Brad
