CLS 55 with PLM Heat Exchanger
Old May 2, 2010 | 10:21 PM
KLR CLS's Avatar
CLS63 PP
Mounted this and the CM30 last weekend. Word of caution, the PLM HE does not fit correctly without modification. The mounting tabs are not far enough apart for the CLS, so I had to drill a new bolt holes. Even so, it;s slightly off center. I sent PLM new drawings, and they may make a model with the correct bolt spacing to ensure true bolt in setup. In the end, it works well, and looks like it means business so I am happy enough.
Old May 2, 2010 | 10:41 PM
khelawanb's Avatar
2006 CLS500 with 55 AMG motor, 2008 Infiniti G35, 2000 Plymouth Grand Voyager
Sweet! I have a Kleemann heat exchanger.
Nice of you to give them helpful feedback.
Old May 3, 2010 | 11:40 AM
TopEndS62's Avatar
2005 BLK/BLK E-Double Nickel.
NICE!!!!!
Old May 3, 2010 | 12:34 PM
m_berman's Avatar
06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
Nice looking stable.
Old May 3, 2010 | 05:08 PM
Roverron's Avatar
ML63
Is this in addition to the OEM H/E or does it replace the factory one?
Old May 3, 2010 | 05:28 PM
DucatiGuy's Avatar
06 CLS55 AMG
replacement...
Old May 8, 2010 | 02:44 AM
dacls63amg's Avatar
2008 CLS63 AMG
Looks mean!
Old May 8, 2010 | 04:54 PM
clstl's Avatar
2006 CLS 55 AMG
Others will gratefully reap the benefits of your pioneering work!
Old Nov 9, 2010 | 06:11 PM
StabMe's Avatar
MB CLS AMG 55
I can confirm that this kind of H/E can be installed with some bolts and a screwdriver.
Well, i didn't do it myself, but guys at the service station did. I've got 55 CLS 2005. I also installed Johnson pump. Can't say that i say any difference. Sometimes it feels that it rides better on higher speeds with this mod. Well, we'll see.
Old Nov 10, 2010 | 12:28 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
They didnt even make a 2005 CLS55!
Old Nov 12, 2010 | 01:32 PM
UDWANIT2's Avatar
2016 E550 Cab & 2011 GL 550 & 09 VROD Muscle & 06 Seadoo Speedster LE .......
Nice............
Old May 22, 2018 | 02:18 AM
FunkTron's Avatar
2006 CLS55
do you have the template for mounting? ....or how you drilled?
the hole you drilled, was this in the tabs or the core support?
Old May 31, 2018 | 07:00 PM
FunkTron's Avatar
2006 CLS55
got my PLM lined up and installed. I took a piece of cardboard and cut it to the shape of the top of the heat exchanger.
I made measurements to find center on bumper and cardboard and lined those up. I pressed the cardboard against the bolts to see where they would end up going and drilled the heat exchanger tabs. I'll get some pics up ASAP.
Old Jun 1, 2018 | 06:28 PM
FunkTron's Avatar
2006 CLS55
What you can see here is that the inner bolt hole that i drilled is the one holding the majority of the weight. It will hold just fine. The outter hole is more slotted and will hold weight as well.
The outter bolts i swapped out for a longer bolt to accompany a few washers. I went bolt --> washer --> core support --> washer --> heat exchanger tab --> washer --> nut. It gave it plenty of rigidity and helped with spacing and the sandwich effect.
I would have replaced the inner bolts with longer as well but they hit the metal bracket above when attempting to lift out. Also, the bolts are not tightened up in the pic.. just in place. Use some locktite and fugghedaboutit
PLM heat exchanger on CLS55
Old Jan 26, 2021 | 12:53 PM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
V2 exchangers are still on sale!
