CLS55 Limited Slip Differential LSD Options
Tried using the search, and nothing came up here as an aftermarket option (for cars without the 030 performance package).
I contacted Wavetrac, and their response is: "Thank you for your inquiry but our notes show the ’06 CLS55 as using a larger differential than our 48.309.185WK (215 axle) unit. We don’t have any planned production to make this unit as it is low demand."
So Wavetrac doesn't offer.
I was under the impression the mechanical moving bits (engine, transmission, axle, most suspension) are identical to the E55 of the same years, but apparently the CLS55 uses a larger diff?
Thanks for any help.
48.309.185WK Wavetrac LSD qty1
2309970346 Mercedes Benz Seal Ring - Interior Flange qty2
2203570790 Mercedes Benz Protective Ring qty2
003531373 Mercedes Benz axle nut qty1
2303500349 Mercedes Benz rear left carrier bearing qty1
2303500249 Mercedes Benz rear right carrier bearing qty1
