My White 2006 CLS 55 AMG Build Thread
Subscribe
Dec 5, 2023 | 10:29 AM
  #126
That is highly understandable. Also weight savings baby
My 20" wheels are 17kg lighter than the 19" original AMG wheels > https://mbworld.org/forums/c219/8443...ml#post8761410
Reply 0
Dec 26, 2023 | 03:11 PM
  #127
Finally got around to weighing the new BBS wheels while I was cleaning and ceramic coating them before mounting the tires. FYI, when ceramic coating new wheels make sure to tape off about 1" on the barrel right behind the spokes and 1" on the outer part of the barrel. This is so the wheel weights have a chance of adhering to the barrel as the ceramic coating can prevent the weights from sticking properly and then they'll come off.
Front wheel 19x9 10.69 kg 23.57 lbs
Front wheel spacer 573.5 g 1.26 lbs
Front spacer bolts (5) 269 g 0.59 lbs
Front wheel bolts (5) 377 g 0.83 lbs
Front total: 11.9095 kg 26.26 lbs
Rear wheel 19x10.5 11.30 kg 24.91 lbs
Rear wheel spacer 1048.5 g 2.31 lbs
Rear spacer bolts (5) 269 g 0.59 lbs
Rear wheel bolts (5) 377 g 0.83 lbs
Rear total: 12.9945 kg 28.65 lbs
Reply 0
Sep 19, 2024 | 02:12 PM
  #128
A bit of warning to folks with cars north of 100k. I just turned over 130k and the crank pulley started wobbling pretty bad, immediately took it to the shop and had it replaced. I was lucky to have caught it in time as it damn near fell off. Another CLS55 was there for the exact same thing but they were not as lucky and the pulley did come off and damaged the front of the block.
While it was up there I had the original coils all replaced along with an oil change and brake fluid flush.
Not much else new other than it has been an absolute time saver on roadtrips especially when the speed limit is already 80 mph
Reply 0
Sep 20, 2024 | 05:00 AM
  #129
Good piece of advice!
I also had it replaced a while ago. Please note that a small amount of wobble is normal with (very) low rpms. I got paranoid and also got it replaced for peace of mind, and the new one showed the same amount of wobble with low rpm
Reply 0
Feb 20, 2025 | 11:31 PM
  #130
Awesome build, great job!
Reply 0
Apr 19, 2025 | 07:26 AM
  #131
Awesome! Great job ..
Reply 0
Nov 13, 2025 | 10:11 AM
  #132
Really annoying that I can't update my top post but here is the recent maintenance done 8/20/25:
Spark plugs changed
Left and right valve cover gaskets replaced
Left and right rear shocks replaced
Front left and right control arms replaced
Front supercharger and drive belts replaced
Front left and right end links replaced
Ignition coil #3 wiring repaired
And bonus picture of the BBS wheels I got last year:
Reply 1
Nov 14, 2025 | 03:46 AM
  #133
Sick dude, your car looks great. I’m happy to hear you’ve been maintaining it well!
Reply 0
Explore
Subscribe
Currently Active Users (1)
