bbirdwell
close
- Join DateJan 2014
- LocationRepublic of Texas
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive'99 and '05 E55 AMG
Liked:1,315 Times in 1,019 Posts
Quote:
Close enough to German I could actually read that! God, I miss the beer gardens...Originally Posted by hyperion667
Alles ziet er geweldig uit, bedankt voor het delen!
And the Netherlands, absolutely beautiful!
nd-photo.nl
close
- Join DateMay 2022
- LocationThe Netherlands
- Vehicle(s) I drive2005 CLS55 AMG W219 C219
Liked:499 Times in 429 Posts
It can be, but we also hold deer memories to our 2 trips to Texas (hillside etc)
nd-photo.nl
close
- Join DateMay 2022
nd-photo.nl
close
- Join DateMay 2022
nd-photo.nl
close
- Join DateMay 2022
Picture from the bypass
nd-photo.nl
close
- Join DateMay 2022
Scored a 2nd hand Autel MaxiPRO MP808-TS. This thing is a beast!
I bought it to calibrate the Airmatic suspension (1 side is higher) and do much more
nd-photo.nl
close
- Join DateMay 2022
Went to work on the suspension calibration yesterday and almost have it fixed (one side is/was lower). Then after being done with it for the day I find this thread: https://mbworld.org/forums/w211-amg/...ts-o-pics.html
I will check again maybe later today or in next few days haha
I will check again maybe later today or in next few days hahahyperion667
close
- Join DateJul 2010
- Locationon my way
- Vehicle(s) I drive2012 CLS63
Liked:3,916 Times in 3,172 Posts
Dit gaat allemaal recht over mijn hoofd!
Explorend-photo.nl
close
- Join DateMay 2022
Hahah does it though
hyperion667
close
- Join DateJul 2010
- Locationon my way
Yah, I'm not really a tech person and still use CD's in my car
nd-photo.nl
close
- Join DateMay 2022
Awesome! I only need a 3.5mm aux port, as I still use a iPod Video 80GB (with the original harddrive and battery)
I dont use any streaming services
I dont use any streaming servicesnd-photo.nl
close
- Join DateMay 2022
Had a mini panic attack as I could not open the CLS, not even with the spare key? In the end it was as simple as swapping out the batteries for some fresh new Varta CR2025 batteries. The key holds 2 batteries as shown below
nd-photo.nl
close
- Join DateMay 2022
And I was able to calibrate the Airmatic suspension using the Autel! Happy days as this solved my steering issue (car pulling to 1 side, even though the alignment is correct). My ride height is back to normal, but I decided to keep it this way for now. Its a bit more comfortable, and I dont mind that at all
Yes lowered looks better, but I dont like the added camber which shreds the insides of the tyres. Solving that is too pricey at the moment (aftermarket arms front and camber arms back) as I have other priorities (cooling system small overhaul first)
!Yes lowered looks better, but I dont like the added camber which shreds the insides of the tyres. Solving that is too pricey at the moment (aftermarket arms front and camber arms back) as I have other priorities (cooling system small overhaul first)
bbirdwell
close
- Join DateJan 2014
If you do not have a new style key fob, I recommend you get one. I have one original key fob like yours; as it aged the battery pack would pull out of the shell if I was not careful. The issue was I had my house keys attached to the key fob. Twice I put my keys in my pocket only to later find the front part of the key fob on the ground. That 18-years-old key fob is now "retired" to backup key fob duty. I invested in two of the new-style key fobs. Pricey but the peace of mind is worth it. Also, if you ever pull the circuit board out of the key fob, reinsert it very carefully; I once broke off the infrared emitter on the end of the circuit board. High magnification head loupe plus a fine-point soldering iron and I had it repaired with the correct polarity on the infrared diode.
Concur with you on calibrating the suspension to within manufacturer's specifications; like you, I found the ride improved and tires last longer.
nd-photo.nl
close
- Join DateMay 2022
Thx @bbirdwell for the tip!
bbirdwell
close
- Join DateJan 2014
Heck, we all have to stick together and share lessons learned. I needed the magnifying head loupe to match the broken solder joints between the infrared diode and the board to ensure proper polarity on the diode. I felt silly because I had carelessly broken the emitter off of the circuit board but I managed to save it. I don't want to see someone else have the same problem; I have no issues with testifying to my mistakes in the hope others will think, "Nope! Not going to do that! bbirdwell already went down that road and it ended badly!"
I keep records of all repairs I perform. The key fob repair description is attached.
nd-photo.nl
close
- Join DateMay 2022
Awesome, thanks for sharing! I kinda have the same idea, hope to be helpful with my thread while I am learning the car myself haha
Changed the supercharger oil again, last time was in july 2022. After this change I will keep a longer interval (maybe 2 years?)
Praise the lord the fill plug is magnetic, else it would have been a disaster when you drop it.
Oil looked pretty ok, until you take a glance at the syringe
Old & fresh oil (Mobil Jet II off course)
Picture from July 2022
nd-photo.nl
close
- Join DateMay 2022
And an Autel scan showed me I had another broken interion temperature sensor. The N70/b1 was throwing an error. I found out its the one on the overhead control panel and got to work. Also replaced the 2x T10 bulbs, as they are probably 18 years old.
The sensor is located behind the little grill on the bottom right
After opening the unit (just remove the T10 torx screws and pull it apart gently), it was apparent why...Broken thermistor.
I ordered 5x new thermistors (type: NTC MF52-103 3435 10K ohm 5%) as they were only 30 eurocents a piece!
Mission success! I checked with the Autel and it receives normal temperatures again
The longest part of this repair was getting the rear view mirror back in place. I used a small 6mm wrench (even grinded the head down more to get it flatter), compressed the spring and stuck it in there, so only 1 of the pins is protruding. Keep pushing on the mirror and simultaneously jank the small wrench out and the other pin will shoot into place, locking the mirror back in original position.
nd-photo.nl
close
- Join DateMay 2022
And replaced the screen protector of the Autel MaxiPro MP808TS with a fresh new one. Well, my girlfriend did this, as she is way better at this.
Before...
After!
Makes a major difference
Before...
After!
nd-photo.nl
close
- Join DateMay 2022
New EVAP canister (because why not). Will need to find some time to replace it
nd-photo.nl
close
- Join DateMay 2022
New aircon clutch. I also bought a new condensor, as the old one is leaking.
Bought another idler pulley, which will go into storage
nd-photo.nl
close
- Join DateMay 2022
Was able to buy a new Vaico waterpump, as they were in stock again
nd-photo.nl
close
- Join DateMay 2022
One of my CLS55 buddies cleaned his exhaust tips recently and I was shocked how much of a difference it makes visually. So I also went to work
Starting point
Work in progress
Done for now, polishing can be a bit better
Left side needs to be done, already looks much better
Starting point
Work in progress
nd-photo.nl
close
- Join DateMay 2022
Was also inspired to do the chrome strip and the logos on the back end
AMG logo before cleaning and light polish
AMG logo after cleaning and light polish
CLS55 logo before cleaning and light polish
CLS55 logo after cleaning and light polish
Very happy with the result
nd-photo.nl
close
- Join DateMay 2022
And some overview shots
Blingbling
Looks like there is more contrast after cleaning/polishing!
Blingbling
