ND-Photo.nl's 2005 CLS55 Build thread
Rating: Thread Rating: 3 votes, 5.00 average.
Old May 13, 2023 | 05:04 AM
  #351
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Picked the CLS up yesterday with a brand new SBC pump and fresh brake fluid. The pump and fluid were replaced under warranty, so happy days!
Time to enjoy it again!
Old May 16, 2023 | 01:26 PM
  #352
New personal best, 8,99 seconds for the 100-200kmph
Old May 22, 2023 | 05:00 AM
  #353
Replaced the cabin air filter (Mann FreciousPlus) with a Kamoka with the same specs. I have never seen a cabin air filter get "fuzzy" , must be a product characteristic
New Kamoka vs old Mann
As you can see, they do a little bit more (or at least claim to do so) than a carbon activated filter
Old May 22, 2023 | 05:50 AM
  #354
Replaced the outside temperature sensor
Old May 22, 2023 | 05:57 AM
  #355
Replaced the broken air guide from the middle skid plate
Old May 22, 2023 | 05:59 AM
  #356
Replaced the Exide battery with a Varta Silver Dynamic (AGM) as it seems the CLS had some issues with it...
Old May 22, 2023 | 06:00 AM
  #357
I finally used the lift on my CLS55, feels way better to work on the car from a secure platform !
Old May 22, 2023 | 06:01 AM
  #358
Replaced the heavy steel skid plate with the newer (?) plastic skid plate. Off course I had to transfer the air guides
Old May 22, 2023 | 06:03 AM
  #359
Replaced the oil level sensor with a OE new one, as I didnt trust the old one and I have no service record when (or if) that has been replaced
Old May 22, 2023 | 06:04 AM
  #360
Oil service kit for the CLS55. 2x 5 Liter LiquiMoly 5W40, 2x LiquiMoly Ceratec, Mahle oil filter and Elring crush washers
Drove 9000km in almost a year
Old Jun 5, 2023 | 06:32 AM
  #361
Enjoying The Mercedes cls55 m113k V8 kompressor On A Summer Day
Old Jun 5, 2023 | 06:33 AM
  #362
This supercharged Mercedes #cls55 Keeps #surprising Me (audible wtf)
Old Jun 5, 2023 | 06:34 AM
  #363
Serviced the JR airfilters
Old Jun 5, 2023 | 07:48 AM
  #364
Upgrades for a small price. Replaced the high beams and fog lights (both H7) with Osram Cool Blue Intense bulbs.
Paid about €16,50 for 2 bulbs which is pretty cheap for Osram bulbs!
Before
After
I totally forgot I already fitted Nightbreakers, so those will be my new spare bulbs Left the Cool Blue and on the right the Nightbreakers
Onto the fog lights. Before (no name bulbs)
And after!
I like the slight blue hint that they give off. Off course the bulbs are far from "white" or blue for that matter, but I wasnt expecting that in the first place
Old Jun 5, 2023 | 07:57 AM
  #365
On saturday I started with the upgrade intercooler. Eventually I had to drill 1 hole extra on the bracket. Also the plastic air guider needed to be trimmed. Also the 4 bolts of the crash bar where a PITA! And you need them as mounting points. Nothing a swivel piece and a wrench could not fix though
The lower grille has 2 plastic deflectors which break over time. Fixed it with some dabs of superglue
The original intercooler was in dire need of replacement, the fins were very brittle and most of them did not sit straight anymore.
The bracket holding the oil cooler in place snapped off
And after some puzzling and adjusting, it came together!
Fortunately, the fitment was about 95%. In other words, I didnt have to do alot to get the oil cooler to lineup with the bellypan. As the intercooler is bigger in every way, the bellypan makes for a snug fit now.
Also start bleeding the system on saturday (as @UncleBenz55 recommended) and I was glad to do so. On sunday I bled the system twice more for remaining trapped air.
Also rewired the pump to run on 12v ignition on and will be replacing the Bosch 010 in the future (probably next year) with the Pierburg upgrade.
Old Jun 5, 2023 | 08:00 AM
  #366
Did a testrun yesterday, unfortunately I totally forgot to log some figures with the old intercooler, but nevertheless...
End result!
Pull from 0-170km/u with a max IAT 56 degrees celsius and ambient temps 23 degrees celsius. Cruising with 140km/u with IAT 39 degrees celsius (also ambient temps 23 degrees celsius)
Old Jun 5, 2023 | 09:03 AM
  #367
Thanks @machild! I also got it swapped out without the need to remove the bumper. I only needed to remove the upper grill to get access to the 4x 16mm bolts (for the mounting points)
I am referring to this thread: https://mbworld.org/forums/w211-amg/...des-cls55.html
Old Jun 5, 2023 | 10:25 AM
  #368
machild's Avatar
2006 CLS55 AMG, 2005 SLK 350 AMG
Glad you got it sorted. Looks nice in place.
Old Jun 6, 2023 | 06:29 PM
  #369
Me too, happy with the upgrade/replacement Onto the next jobbo!
Old Jun 11, 2023 | 05:18 AM
  #370
4 new Lambda sensors from Bosch. I lost the most time on getting the connectors out. I filmed some videos whilst swapping them out, will post them soon.
Old Jun 11, 2023 | 05:19 AM
  #371
2x 1Liter LiquiMoly 75W140 for the rear diff. I service it already last year, but will do it again so I can hold a longer service interval for next time. Last year was probably the first time it was seviced...
Old Jun 11, 2023 | 05:21 AM
  #372
New OE acceleration sensors (used by Airmatic system). One of the 2 was throwing errors, I found 2 of them on eBay (new!) for the price of 1 from local MB dealer. They sit right in front of the Airmatic strut in the engine bay (2x 8mm bolts per sensor)
Part nr: A0009056502
Old Jun 11, 2023 | 05:23 AM
  #373
New Lemforder engine mounts, these will replace the Meyle engine mounts in put in last year. Was notified by a buddy of mine and also noticed it on Youtube channel from M539 restorations that Meyle are a **** quality...
Old Jun 11, 2023 | 05:24 AM
  #374
Working on the rear diff oil change
Old Jun 11, 2023 | 02:36 PM
  #375
UncleBenz55's Avatar
W211 E220, W211 E55, W203 C55
Do you have a LSD?
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
