ND-Photo.nl's 2005 CLS55 Build thread
#551
I have given up tracking down any parasitic drain. Sometimes the car is fine for several days, other times it is "convenience features disabled" after one day. I have been through all 3 fuse boxes with a multimeter looking for the culprit and can't find it. Battery tests fine and is not too old. It seems to be well correlated to cold mornings for me (under 10 degrees C).
#552
2006 CLS55 AMG, 2005 SLK 350 AMG
#553
Do you know or check the voltage of the main battery when you receive the message? One of the best ways to find a parasitic drain is to use a thermal imager connected to your phone. When you know the battery is under increased drain use the imager to find what is awake and casuing the drain. Any device that is causing a drain will generate heat.
#554
2005 CLS55 AMG W219 C219
@machild say about 3 days before I get the convenience functions disabled. Both main& aux battery are new. Voltage regulator new and confirmed that its working properly (14.2v loading).
I found another thread indicating either the BCM or F32 prefuse (the capacitor).
#555
As you might have seen in a thread in the W211 section, I did a dynorun last weekend. It didnt show me the information I expected to see, so I suspect something went wrong during the measurement. The thread can be seen here: https://mbworld.org/forums/w211-amg/...ent-wrong.html
Dyno results 457Bhp / 717Nm at the crank. That would mean: -20PK below stock and +17Nm above stock. This does not sit right with me as my dragy results seem to point to a higher power (pun intended :P ). 100-200kph in 8.99 secs
![](https://lh3.googleusercontent.com/pw/ADCreHcdgSy-QVgIxosUwjqFbi3x6voYpK27oR3w4-hSFbCEGIWqSEPF6CpRolVqRjrI_jRK7RlmcboLTsVZ8lUjBSdF5F0Ho69yzFeYaSPuWQcWj1n_qhiiyRKRBOhDJGlx8dvLGAQF4xDfvScLczycI_HU=w1600-h900-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHfYNEqSeWGzTwJpGN_KDybtxM8avdUyY3kXAin2cwwdD7VffvcGzyWpM4ayuMaObmmO5Usvp7IbUkTjy7LK2s6DXSq-Ea1gX7HWk_wfTkGg6JFtaWH193OFI3qSWtcDp_pvKhNLGtx4grBdnRtEsNAm=w1600-h900-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHcv2k7Y_8qyMdu5ULCbm0pN5nhgzuvS0Lz6u8zdJTmeEvuFZChwC_aCptpZFH5p8Vk1L14LsVwRYcWJXJ3a1yJ6dqzRylNpReMCglffsoHam79WaXQpv-aCAIXHRIbsDcyCjOkgTQm0TmDqxNRDfFsT=w1600-h900-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHfxwE6lUFb1x_2cK5lM0tUW6TSm8div-D9GGkW7891lWIxv0Db1Y52joLxAjrRx9Cd2yST96bMxbOEULQd6nZxqBq1Txk42xElsbTDK0rAnr7UjZPoJVWbbbzGp27X8zPxqsaI4T4eczsQ7xjs-mpp5=w1600-h900-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHfJH06MTmFY7brVSgoAQdpObg57OiN0z-frHsDjyRTG2u8VItafOEuB0FEaqL2mjXznYx3bWStopqa2cmqHXeELsIDK_R4MWQzC2Af7LUlzF2emTLASrFnXnpOunvs_9Nw8Yqt2vQNgW96xHQoW2t8X=w1600-h900-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHdn0WyN30n-S_M24gC0YnPLcIzRgon3rg7khHDoOnycMX5EyANW7pHWKm7V9EjaKRmz7y9fcZLlCQoF8zA_RxlscW0521XVex7EwfvRPf9PEmkOG85UxKkfrknVaod-TG7AxlRL4DCC34F43hdt4a1I=w720-h1280-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHduccDxFGZN99bADOoJRgdNt4iCo3ADAm2gimCFahnJv-C1n8T93yhqffm2vhmSP7quRa_dLJtaWdkWZB6pAiFsFD6H9wKROmUlbVKG7EsFccW6PGiaA-yJof5MTN3bBEkD2R-f0WxOBZmsa1DeE7k1=w1600-h900-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHe48vcK3xuqwgnRfIvJ3UTjUq9QAikj7kIp-ElyKYihm5Nf8aQjsOCUdoNq7sWiC4F3dssUjinrWhwZSiMap9bGj0acCPQIYklz66v8cwRz5pc1N7MYM-2JkUVXjhtUrKOI3sR77RbiG1hjntfuo3Fo=w1600-h900-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHexKoEVlYZqvxckrp3KGaUkmqSYg6wJViJxw16bxZ_EUupcHyieKJABNSshZYSgBw77uxSS2SBUr41_lHv9kKT6lJM0hUw1iRUgzoAjP68jRHPK3kqXl_cSKWcla1prdmBcGIFYs3EyIP-BvFnPk_TY=w720-h1280-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHetnpNe0RouDUD59D1WV4Yi4RojskZdDVytJ2_d4NRq0PROKWzcdJnCBcNnAB4Ro-Fcy7Vhr05uvz8IuK6aAxsOGLYX9emmruL25C5kHxhPiVJJYe9efuiktoUHMr2N9pcByCBmW4DvfjqQcpjN5j5T=w720-h1280-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHeJRpM9f1oZd1WqvljvN-s7GW9lAZiPUbSRAz4CxMpapsLW2_MMyMQ7xACvEOyzPGuFVWM5joJ5B3up5I0BQcrKCJqVkrBwVO4gMGEWjHcR5oW9Ianvnb48GFYWlH-ikFId81tpvNTTFAAUqdkj2S-T=w1600-h900-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHd0zEUKf1LXO6qnJWNu8qNm0yEiNORfsbJmFTi0WQeZgdxjargd-gnYeGjTABNjnkQqR58lUyW3DseA4oRR4bsW3xMHJzlf0ntfSUoYZrgSI3x3BtsJVQKbGsj1fQ_fTOGq6HStcYD1EL9Iv_CrVaqk=w1600-h900-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHckADth3FxfWchMgHw9w1B_BC-r6dcobILxbHYNuMHjuIBJvit4wbYXYHoC4vxL1ZlJPqcXi36HdIJwxgwIiC03Opyz19lfkTsn6cOzB0JaUtX8p4IM_jLwMjZYB-Sv9wtwsaxRygDzvZLxktbIRqxY=w1600-h900-s-no?authuser=0)
#557
Also replaced my crank position sensor not too long ago. Was easier than expected, and only found maybe 1 video which shows where it is on the M113k. I also filmed the replacement process, but it seems my headmount was pointing too much upwards, so the video of replacing it ended up pretty useless...
Nevertheless, the replacement should be pretty self explanatory once you see where it's located.
![](https://lh3.googleusercontent.com/pw/ADCreHdUZ4b8SvRRY64mIfik1MPmEjnGuEJuSPCtm_CgBN-FIvxGUwMQRyVoALLnMwHbGogBYjVnGqmzXtyL0aVsoS8X74JwEfPIepsecxSfn8sE8CnlrplxRWZIpOAcesNet7Iyh8X7KrY3uUJsGmS7bvqx=w1600-h900-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHePFg_TyRiKgL0Xm0Shlx5KAMjAf9kb-8wIEWNsi_s4_ERfRoZzUbzRZzGMXYCxmBpo721PelpimscYrmgSyr8gMplHLWskHRVv6gVCSMqxz1QTqYBLOsbJPVzN2KTup5s8u7dBeMi2B_khvfThZasL=w1600-h900-s-no?authuser=0)
I opted for a new Bosch sensor
![](https://lh3.googleusercontent.com/pw/ADCreHeJcnL8NO3dwk-2FuxVjlc7dESTxjuI6SBUAVWAQAx-XjYYgHxExJOUVELeHfjMvHtC9nSYKIKlnR6I7Cf5J1p6htfdTcQ8lPHXaiP5HNDs3PhkR2VibNvlMWIwIPjyDwg7xiOPwfw84bPZewb4mvjj=w1600-h900-s-no?authuser=0)
#561
Swapped over to the original wheels with summer tires again, to save a little bit on the 20 inch
Also if need winter tyres, they will be fitted on this set
I still love the look of them!
![](https://lh3.googleusercontent.com/pw/ADCreHczlVjrjFIVVE_W0MttC6NIJqI31ie9bPbTIva0w_brdzqDI9eu3LOaHCPDv407TQcYFERmTTayZYciaN4YM5WOc0Rka38JQhfczQyvQgTHZDPKZcng0mf4cUNdUqO0gvt1mXLV2jGHUKAkHbI6mtrs=w1600-h900-s-no?authuser=0)
#565
Some steps towards solving the parasitic drain, replacing the old style Battery Control Module (aka BCM) with the latest revision (came from a 2007 E-class if I am not mistaken). Layout is a little different, but the connections are all in the same place. On the E-class, this sits in a place where water ingress is likely to happen. The W219 BCM location is much more safe in the back of the trunk.
Partnr: A2115403845
![](https://lh3.googleusercontent.com/pw/ADCreHdeLZsRmb-Mk40Nexq7zOn6-8yvdIEzu6SJx1gVdJXK8Chplq7DpROhlnxpMusD3OjS75zbIyzGu-l5QU6YnJJmeH3ElnTvP4tC2VVBlLVV4srhvo7DO0ydR7X0wCl1o5BA5xV5RicbvjhsCyAPcUdM=w1600-h900-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHc1j7BCUgolikgCv9JfB3NwjRvAlSaIp4ZPZG00uYBSFbrfSjd8r1qgSp-ld909SQfyM8Q9lazEZrVfBfIa3H6yRjKJvAZNmlnvEt2w5u8bXjoBcyxLKFGj4Pq7T-iICRNj_5nQwODBSnoOZJgU3rGL=w1600-h900-s-no?authuser=0)
After some cleaning with a scotchbrite pad
![](https://lh3.googleusercontent.com/pw/ADCreHcegidRku89OuKqtCX1cHJMZUcWZWCb9UBbD0Kxb9suVLC3CKCov2c0wyCy6grIbPxfal1v3DMYZDwwYfP5BdnGAYNODuQ63_G0FFD6BpZl9ZIM4yHfVSSCk1QMrAVANjbURknMaiWcgX8KsHHodYJ2=w1600-h900-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHeSGvSBuKGA8TpqdMzP8TlQOpU_lIJoDLWfM2aEq0c_SEMINhtq-Eh341FyZNIOZ1d5uAlGOdZ2KO0v2uUt3secmRqZleyKe20G5_JOgM56G8BsmDBtOlSdI70w6tqz91TnWQXqkdPVrPPknoVGyQaL=w1600-h900-s-no?authuser=0)
Old & newer compared. I read something about the old one being an inherently faulty design
Old partnr: A2115406945
![](https://lh3.googleusercontent.com/pw/ADCreHcUWeD-eRJUn9dnKa6LvMCed4I0eq7-LCg4X0O0SG1M2qeVmOacalzIeJX1z5PvU91cAwiCuA0UzLYe91kh4VQ4ql9WfC8oMmTvtOFn3MBjk68UcNpbwxPetoGJVv_ox3Dq1_XUNwMBMz6U1RYSG34E=w1600-h900-s-no?authuser=0)
Unfortunately, it was not the solution for the parasitic drain. But it works perfectly
Partnr: A2115403845
#566
Removed the alarm siren, as I read that the onboard (non-serviceable) nimh batteries will leak over time, keeping some module alive to charge them (infinite loop). Also not the solution, and I will replace it with a brand new one in time
Some dirt accumulated in the wing, I will check the other fender in the near future.
Partnr: A1718202526
![](https://lh3.googleusercontent.com/pw/ADCreHfVI-GwM4CkuucBtKbuO4GhwNlLVZyElX51NW2-K-UAtxNhaG0pkeOopwgmchPrFdRVpWFX2Grp0aa5JcVQRbKFScHZKCf6CY8OseyBX025mvFJb1hLY5Rj1WCyP_pQ-VBo17PCJEwOc6Oz_GeQ-Ail=w1600-h900-s-no?authuser=0)
Rusty cage for the siren (we have a sea climate here in NL)
![](https://lh3.googleusercontent.com/pw/ADCreHeEu19eopYuz7HL14UA1dBTjLNuC4X3UKu-jT6iCjIeJFh-q9A9GhdFcSXYTWp_jrwqJAVYnx1LqEj6ht1Q5uoImFb6HaL0ZhLlabw0oD4Gm72u87byvG0O0Do90IJBrGCvxOS-1oPpEbPobEUa8u4h=w720-h1280-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHeGuUhxjAzCt-OfrHa5QarXHHWDK2mM6GxVH269RYi_xw9Wg-IoW7ikCw_7-zj18h_FcJDM4KKGBEDy_rVtnwplmqVb_piC9vZqDOfUj4RyIURJhJzRJgHnslXHqTQDoNux4mmcjMhAuNwzvULweK-9=w1600-h900-s-no?authuser=0)
Partnr: A1718202526
#567
Removed the old Nokia phone + charger / docking station from the center console. The charger felt quite warm after letting the car sit in my garage with the windows open. Right now, ambient temps are around 10c and this felt warmer. I thought I found the smoking gun as @machild mentioned, but the drain remains.
Its easy to remove, pry the top part loose and then you will see 2 connectors which unclip easily.
![](https://lh3.googleusercontent.com/pw/ADCreHfH2NX6KbV4xvNwNE-G46vCelnWNS82bd_2zKFn9byESr8GpmKDKmVm3pN9dF_MBaPkxcNOcUkDsYEeA1wvk-Y2MqB_N86jI00Z6MRZiJiEz76OC7Nfo_zL7mZbFDXe30N8YHcpbC9II1SZ2ve_8te8=w1920-h1080-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHfe2_BTrWYZHnvP2Z7GJLNnQfGxJYh0VSbT2Mx1Kn-VfJpsOy4nZ8M6pTQ4CxntzrHfcre_Z1-QV75uhJjF0E8jATA3o2cvSGIN9mfhWyWmeB5LqZLNxgOXHgHUqj3Ll1HWxoabjFBzcYv57mNbhpj8=w1920-h1080-s-no?authuser=0)
#568
And removed the phone holder and bought a 10" screen for wireless Android Auto / Apple Carplay. I will only use this for navigation purposes and it works quite well! Not the fastest unit, but you get what you pay for off course
Link: https://aliexpress.com/item/1005005789755035.html
#572
Replaced the AUX battery relay. The new version is a lot heavier than the old version
![](https://lh3.googleusercontent.com/pw/ADCreHcokFmyRo5TkJ8Y2d75w7UKUxchXxTpWkmr-4QGLQiNbQLNIalfqf2-Ul7nrLwr036Jkmy3nECefBit_VDF0aeabdC5xJc_L24am57vKw1khnH4h6oonPPKn8XLJCKPtFrZoVRkjb1Kf4BuCemcRiyz1Q=w1920-h1080-s-no?authuser=0)
You only need to remove the cowell partially to gain access to the relay
![](https://lh3.googleusercontent.com/pw/ADCreHf2Mgt611h50xRn4C_wwY70qtBEj_XdvyZz9u2BESH1eLdDdDuvN-ubS3_n049eXQhhskIigtF-PPVH2Z0hDRPuIzP9urhqgOkjvJw5gURR-c2UK0KK4seEEOnt5930WrU_SHhxZ9UHGPLAkF5eELwLSA=w1920-h1080-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHcpU8hK5wOl6XNdt9qpCozaA_zPBWLXT9NGuzoQ4KL3YdbeBt018B9nQmfXhx5c-kJQymUHB7LKGwMd6HOP02oAk_rU6zHHLIVu-a0Gwh1BgARgHrKLjd2j_1KorKxv-mUlcI1gB21CJ4l31al8HdKw5Q=w1920-h1080-s-no?authuser=0)
Old vs new
![](https://lh3.googleusercontent.com/pw/ADCreHeZR6on4w6QoLitxd5K7vA98qD_SD5rnLs1w2Io6OfdIWwPc-vb_iTnBm4h62WwTfuq5B1Vh4OpOJ-3klHy1ZgEMFxgB4bDGprQyRLKfUOkVJnPIO2ycagBHlRsXF17PlB8K1zV-gZwQBoCFRbCsbryeg=w1920-h1080-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHdVThrWYs0HgoumamPNaHYFCILGzI5bH11sKYWltWd9F3lN2v0XbRvlXFIHTv1VBVVbNrAkpl_ciKtrzxB2_-jKqyqiv8zX7WHYAmgV3wrzv07PA44a1YsRawZTsp6DWfhQh0zJdIuOMQJBk9rf7V0Fyg=w1920-h1080-s-no?authuser=0)
Some error messages I got
![](https://lh3.googleusercontent.com/pw/ADCreHe60dGiwdJyuW5-2lWwNPDIKsXe0ArSLeadiuOnT_lIbBpYkp_bvnlioFpukViQ7xnuo7a7AGFP-sA3YwzY8XiWhLM-rp__XDb2giUho7t5-PbaupJK1qfjSFBzLv8F167o1DtRc08devzMAW3i5qH2pw=w1920-h1080-s-no?authuser=0)
This message presented itself after replacing the relay? Fortunately I had another AUX battery lying around. After fitting that battery the error message was solved...
Old vs new
Semih Atabey (03-11-2024)
#573
Also replaced the drivers side mirror glass before it really gets cold over here. I replaced the passengers side last year,
I learned 3 things
1) The original mirror also has auto dimming! Quite fancy for a car from 2005, I never noticed it though
2) Mirror heating works automatically, based on the ambient temp sensor (12 degrees Celsius or colder)
3) Aftermarket mirror does not have auto dimming (not a dealbreaker for me)
![](https://lh3.googleusercontent.com/pw/ADCreHfw5yQlxA0EvYzbAPbw0JlekCLOHW6NSQYxVu7aP2WLPuV6SDGodAsEeXOpZ9ry-jXqTEBhjfJDPpelgqd5RZVZFbzAyvoixKpalAg8ZM0OMfe_4SI32bzS_sVwCpTYzbM_hETp-w2ZCNYG5pV_Etz7Hg=w1920-h1080-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHfIeGH-PaJxOwJECgdUvl7sXtaQJ-oHpWtgPR4lN6-yGmF84g0NwwuxRrSHWFUt7Hi4ON386jGD7Rlz0OCVOfsckovv40W3dtT-1eVcVsBNxy9s0RaTg_-V32Rj9LUoEqNSWT7wDEfoUGxJtAhIkgTM-A=w1920-h1080-s-no?authuser=0)
2 pins for the heating function. It does have room for the connector for the dimming function haha
![](https://lh3.googleusercontent.com/pw/ADCreHfwBCSE-sc2l_AMhivcU28saBB04x32vSMTigl20PwJj1zPAz18XwYoUvgu2eLA3XLQArBYWtV6gBJil4hL6qA0x1dOQMWlDmT0c-xNqrx_WeF34mlNodKv1PwWThDmDTyojneq88hoHrxy903slTGHAw=w1920-h1080-s-no?authuser=0)
Original mirror glass
![](https://lh3.googleusercontent.com/pw/ADCreHfkeUcUDFVHJ8W6i0kPI3U4TJSLqtEBt9cCQgKHskfiBha73PsCoQpDY3y77r-qCKz6mVW6EtyxYI_BS9s0G-TAvJkKa3oarGIqkhA92IbzhZAOR9RJm8wa6wBiU8vsUKhCwIjjKTFHFyH7wMbCjmQutw=w1920-h1080-s-no?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHc26i2zYJJ49dCn7NBgMgdzNlWWLt-hvZQiyX9y5N9o-rAlYqWMbnBpF6RMPAGIOEetAbfNQXsqBtUlLromCTR8PD3naGbr9Ln1YTqQ-CzzkP4rcIMBwx5375jiynTaw9ZKuhWae-CT81u_yaS-JDCuPQ=w1920-h1080-s-no?authuser=0)
Closeup
I learned 3 things
Closeup
