ND-Photo.nl's 2005 CLS55 Build thread
https://www.aliexpress.com/item/1005003575422609.html
https://www.aliexpress.com/item/1005003228764160.html
https://www.amazon.com/Arotom-Covers...S5K/ref=sr_1_1
The Macguyver solution with reinforced vacuumhose. The hose was strong enough, but the clamps dont give enough force.
New airline in place. Had a piece of hose which fits the airline perfectly (added protection against rubbing).
They are quite easy to replace, start with the window open, you will see 1 tab exposed. Lift it with a flathead screwdriver and then you can continue from the inside. On the inside there is a hard plastic piece of trim (in the front of the window) which slots in the trim (on each side) with a small tab.
New vs old
Problem solved!
New arms, thrust arms, inner + outer tie rods and lwer ball joints
Special tool at work
A little looksie behind the knuckle
But then I found out I had the wrong ball joints delivered. So project was coming to a stop...Ball joints did not have the lip to press them in.
Had to use some heat (torch) to get the 21mm nut for the outer tie rood to break loose. Then I also found out my tie rod toolkit did not have the correct size (41mm). I made the decision to keep the inner tie rod for now and only replace the outer tie rods. gave it a good lube with fresh ball joint grease.
All 4 suspension bolts looked like this. Why...
One of the outer tie rods looked like this
Couple of days later, the correct ball joints had arrived so we could continue
OE arm vs new aftermarket arm
Decided to also replace the upper ball joints (correct choice)
Everything in place! Need to do an alignment next.
10 Liters of Liquimoly gearbox oil
Servicekit
New conductor plate
Dirty valvebody (see the black residue on the valvebody)
New conductorplate in place
All back in place
In the end, I performed a reset using the video below (method 2) and all was working again. So the 2nd drain wasnt needed at all
My specialist paint booth, temperature controlled and everything
Work in progress
Here you can see the clear difference
That is the last time that I will be buying Febi Bilstein gaskets. I replaced them with a Viktor Reinz gasket. I also added high temp silicone sealant to seal of the oil filler neck, as oil was seeping from there as well.Oil on the exhaust manifold
Sealant around the filler neck.
https://www.autogespot.nl/spots?bran...country=&city=
