ND-Photo.nl's 2005 CLS55 Build thread
But as good as it looks on pictures, it does have a lot of small surface scratches all over the car. Hopefully, somewhere next year, I can have it polished/corrected, as this car really deserves it.
Also a safety mod, which is probably the first over here. I bought 2x Lifehammer Evolution from the Porsche webshop (as they are half the price, 9 euro compared to +20 euro). I bought 2 for the CLS and 1 for my girlfriends car. Also, normally they are orange. Let hope I will never need them
In all seriousness, the front punctures a car window with ease (ceramic pin comes shooting out) and the handle holds a razor blade for cutting the seatbelt.
The most exciting moment was if they were able to get the bolt loose, as they had issues with it in the past. When they cant break it loose initially, they need to invest some extra time to block the engine from moving.
In about 15 mins, they had access to the crank pulley and the bolt
Another 15 minutes later, the car was lowered and I saw the mechanic remove the old pulley from the engine bay (nice!). I inspected the old pulley, and the distance between the 2 parts seemed identical all the way around.
Another 15 minutes later and the new crank pulley was installed.
And after another 15 minutes, the CLS was ready for takeoff. Testdrive went well, and I was on my way back home again. I also asked them to install a new front main seal, as it was accessible off course. They charged me 760 euro, which is really fair price imho
I asked for a quote at the dealership near me for:
-Crank pulley
-New crank bolt
-New front main seal
-New airco condensor (as its leaking)
-And the labor to swap it all
And I was quoted 1.900 euros
I recieved this address via a dutch Mercedes forum and I am glad I followed that tip.
-Crank pulley
-New crank bolt
I was planning to install it somewhere last week (or this week), but it will be postponed a little.
I hope this helps.
I hope this helps.
[edit]
Speaking of which, I replaced it with another one which supports Quickcharge for Android, as this is a lot more functional
End result! The button is the on/off button for the voltage gauge
Old & new
Comparison old & new. I see now that the drivers side has a somewhat bigger gap around the headlight. Will see if I can adjust the hood a little.
Very happy with this modification, is a lot more subtle than I thought, but looks way better imho
Aftermarket or OEM?
Funny, when I look at your car, your passenger side headlight is a bit "clouded" than the right side
On my car, it is the opposite
So I will trade you my cloudier one, so you can match!
Just kidding.
I wonder what causes one side to do that over the other??
At this moment, the somewhat cloudy headlights dont bother me. But I might take you up on that offer @MB Knucklehead
Maybe using different type of bulbs and not replacing them both?Or do you mean the bonnet? I think it has hit something in the past, nothing to serious, but enough to unsettle things. The bracket behind the grille is also a little bit bend out of shape.
Tank was filled with about 75% RON95 petrol, and off course we were with 2 people in the car. Very happy with this result, it shows I have a "fit" example
We also took some time for some pictures
