Evosport SL55 Intake Modification Kit
1130941682 $ 7.00 Hose Inlet #1
1130941782 $ 6.75 Hose Inlet #2
1130900601 $ 98.00 Airbox #1
1130900501 $ 98.00 Airbox #2
1130940103 $ 44.00 Y-Connector
1130942382 $ 7.00 Hose
1130942482 $ 7.00 Hose
1130100967 $ 67.00 SL55 front engine cover
Anyway, it's a fairly straightforward installation.
http://www.evosport.com/product/prod...VO.PER.M03.I01
The baffles indside C32 inlets are mufflers, designed to quiet intlet noise down. I would not worry about getting water inside the engine, one would have to be in 3 ft. water for it to happen.
So, the kit will work as is for 2-3hp but if I want to do the full conversion I will require the following still right?
As far power gains, on stock car you will get 2-3HP, on Stage II car we get close to 5-7 HP at the wheels.
The more basic mod (just the splitter and hoses Vadim described above) would be very hard to see.
A MB lead tech told me about the water mitigation function of the C32 inlet tube baffles and to use some caution in extensive rain or flood conditions (where water could be splashed up into the grille). I haven't noticed any increase in intake noise.
No other AMG cars have them and they have a very similar intake setup. For that matter all MB cars have the same twin ram-air inlet.
How about Evosport Stage I C32s? how much gain can we expect with just the hose and splitter and greenfilters on a stage I car?
BTW: this new product is worth considering
i ll need this when i get some money hahahttp://www.evosport.com/product/prod...VO.PER.32K.PS1
i saw this Intake Manifold Spacer over on the other board. Are these also gonna be made for C32? if so, and if we can stur up enough intereests, can we get a group buy price here? thnx
Dave*
Wawy: The complete conversion is not that that diffucult. If you do a search there were a couple posts a while back with full d.i.y. instructions. Need any more help feel free to ask
i have the green filters and don't want to buy new ones if not needed.
I'm thinking of doing the plugs and wires first and the IC pump replacement than the ECU.
sL-55 is not that high in the list, it would be nice to have.
TopGun32 :" I'm thinking of doing the plugs and wires first and the IC pump replacement than the ECU "
Replaceing the plugs/wires and the IC pump are great to do, especially the IC pump for reliabilty. But they wont really give you any hp. The ecu will give you some more hp, but would yeild more hp if combined with some combination of the 55's intake mods. Either the Evo Sport Y piece or the full 55 intake ( Y piece and air boxes)
The C32 filters will not fit the SL55 airbox. The C55 filters do though.
correct..
the wire and plugs are an easy mod.. and the IC Pump is more of reliability. Right now, I feel the car very inconsistent. Obviously the heat is really affecting its performance.
Even if the Bosch pump is the same, I rather have piece of mind that its new and in good working order.
The ECU obviously is the horsepower mod, but at this point I dont think its really worth $1k for 15RWHP. I have to do it eventually, I just need to find a good deal. I'm thinking of going with SpeedTuning, but it would be a hassle to send my ECU and take before and after dynos.
