where can i get a shorter rear diff?
this will have a (prob big) impact on drag and circuit racing times.
any info will be appreciated.
thanks.
I actually would like about a 10% taller rear gear.
Vomit i think you are wrong.....i will try to dig up the car and driver test of the slk55. it was faster than a c6 vette with 400 hp and lighter weight simply due to the mechanical advantage of lower gearing.
i don't think there's a significant gap -I took a look at ratios for the 7 speed vs the 5 speed and calculated the overall gearing and rpm at entry in next higher gear.
7 speed- to redline in 1st, then upshift into 2nd at 4375 rpm -to redline, upshift into 3rd at 4494, into 4th 4782 rpm, into 5th 4893 rpm, 6th 5495, 7th 5950. (last two are overdrives).
5 speed- to redline in 1st then upshift into 2nd 4088 rpm into 2nd, 4310 into 3rd, 4756 into 4th, 5539 into 5th.
granted the slk55 is lighter than the c55 (but c55 has a Cd of 0.27) still the 1/4 goes by a good bit faster (almost 1 sec?) so that's gearing.....(?)
does anyone know the 5.5 na power output past 5700 rpm?
edit- the mkb diff includes a lsd
I am sure that it depends on track conditions. With a sticky track, lower gears would help. With a slick track (like Carlsbad, where I always ran) the prob was getting out of the hole.
.......also re gearing....the 7 speed auto c350 is as fast as the 6 speed manual despite the more lossy auto tranny.
The smallest diameter rim to fit the C32 is a 16".Vomit: Carlsbad was a slick track but I always had a lot of fun there!
Too bad they shut it down....
