C32 Performance Enemies!
02' C32 AMG
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Which is the worst enemy for our C32 performance ?
1) Bad Gas
2) More than one passenger
3) High Humidity
4) Hot climate
1) Bad Gas
3) High Humidity
4) Hot climate
2002 C32 Black/Charcoal
1) Bad Gas
3) High Humidity
4) Hot climate
1) Bad Gas
3) High Humidity
4) Hot climate
Originally Posted by Vadim @ evosport
You GOT to loose that body in the trunk!
Bad gas. If you can get 93 or 94 use it. If in CA try mixing 100 from Unocal.
Slow moving objects (in the fast lane!)
Originally Posted by Dead Ringer
heat soak kills the supercharger!! I should know about this, I live in phx az and when it hits 100+ a scion xb can give me a good run ![mercy](https://mbworld.org/forums/images/smilies/mecry.gif)
Ordered some Cool-it padding I'm going to install under the airboxes (SL55 intake conversion) to hopefully help this a little since I've read about some positive results by the E55 crowd doing this. Anyone know if it would also be worth wrapping the intake tubes themselves since they also make an wrapping for them ?
