What does torque really mean?
Old Oct 22, 2005 | 07:49 PM
MrMuse's Avatar
02' C32 AMG
Yeah I know a little bit, but can someone explain what it really means
Old Oct 22, 2005 | 09:35 PM
respdoc's Avatar
CLS
www.google.com
Old Oct 23, 2005 | 12:20 AM
Vomit's Avatar
2002 C32 Black/Charcoal
Let me just put it this way. . . If it wasn't important, do you think that they would name a wrench after it?????
Old Oct 23, 2005 | 12:26 AM
Vomit's Avatar
This is mini vomit(Vomit's ten-year-old son. Torque is defined as a force that gives a twisting motion.
Old Oct 23, 2005 | 12:27 AM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
I've always heard.... "Horsepower sells cars, torque wins races.."
Last night my 400 ft/lb torque/231hp CDI ran a 15.5 1/4 mile... which bested a bone stock 1994 Mustang GT that I saw run 15.7 and a few other "sports" cars that have low torque..
But.. (and this is a big BUTT)
The real kings were the vehicles with high torque ABOVE 3000rpm... which is where my CDI falls short. Torque at the higher RPM band is key to being fast, and is why the AMG cars do so well.. My torque is GREAT for around town driving or passing on the freeway when you're pulling 2000rpm or so... but when you step on it, after about 3500rpm, my car has to shift to keep that torque level... an AMG or a typical high performance car can ride it up into the 5000's and more.
Torque is power
HP is power measured over time
HP=Torque at 5650 rpm (or something)..
those are a few pointers that should get you started..
Old Oct 23, 2005 | 09:48 AM
MrMuse's Avatar
02' C32 AMG
Thanks,
Yeah I knew what it was, but I had to be sure. I forgot that I learned it in fysics. It was a while
Thanks anyway
Old Oct 23, 2005 | 10:55 AM
benzmodz's Avatar
W203 slightly modified
Torque is cheap but not when you multiply it by 1000.
Old Oct 23, 2005 | 11:04 AM
CE750's Avatar
well, actually you need more like 4000-5000...
Old Oct 23, 2005 | 11:20 AM
2QUIK4U's Avatar
Where did you take "fysics"?
Old Oct 23, 2005 | 11:50 AM
U2fast4me's Avatar
(Torque x Engine speed) / 5,252 = Horsepower
The engine that makes 300 pound-feet of torque at 4,000 RPM produces [(300 x 4,000) / 5,252] 228 horsepower at 4,000 RPM. But where does the number 5,252 come from?
To get from pound-feet of torque to horsepower, you need to go through a few conversions. The number 5,252 is the result of lumping several different conversion factors together into one number.
First, 1 horsepower is defined as 550 foot-pounds per second (read How Horsepower Works to find out how they got that number). The units of torque are pound-feet. So to get from torque to horsepower, you need the "per second" term. You get that by multiplying the torque by the engine speed.
But engine speed is normally referred to in revolutions per minute (RPM). Since we want a "per second," we need to convert RPMs to "something per second." The seconds are easy -- we just divide by 60 to get from minutes to seconds. Now what we need is a dimensionless unit for revolutions: a radian. A radian is actually a ratio of the length of an arc divided by the length of a radius, so the units of length cancel out and you're left with a dimensionless measure.
You can think of a revolution as a measurement of an angle. One revolution is 360 degrees of a circle. Since the circumference of a circle is (2 x pi x radius), there are 2-pi radians in a revolution. To convert revolutions per minute to radians per second, you multiply RPM by (2-pi/60), which equals 0.10472 radians per second. This gives us the "per second" we need to calculate horsepower.
Let's put this all together. We need to get to horsepower, which is 550 foot-pounds per second, using torque (pound-feet) and engine speed (RPM). If we divide the 550 foot-pounds by the 0.10472 radians per second (engine speed), we get 550/0.10472, which equals 5,252.
So if you multiply torque (in pound-feet) by engine speed (in RPM) and divide the product by 5,252, RPM is converted to "radians per second" and you can get from torque to horsepower -- from "pound-feet" to "foot-pounds per second."
Old Oct 23, 2005 | 12:25 PM
dragonAMG's Avatar
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
My guess is Ebonics High in Compton CA
Old Oct 23, 2005 | 12:55 PM
JamE55's Avatar
Out Of Control!
lmao :p Do you have any hoetel rates for me?
Old Oct 23, 2005 | 01:36 PM
RLS's Avatar
RLS
1980 928S Porsche, 1965 T-Bird Conv., 2006 C55
torque from what I understand, is the low end "grunt" power. It is your pulling power. If you have 2 engines both the same size displacement wise , but one has a longer stroke with less piston size, it will have more torque. HP comes in at higher rpm. A good example of this, is the old 454 c.i. Buick and Chevy engines. The Buick had more torque because of it having a longer stroke, but the Chevy one had more hp. If you were to hook up a heavy trailer to both, the Buick would out pull the Chevy one any day. Now if you can keep the rpm up on launching, than you torque will not have to be that great and your hp will come into play.
Old Oct 23, 2005 | 01:51 PM
dragonAMG's Avatar
hehe... even though it's Vegas, the hoe is not included. I should have some rates back on Monday. What is the exact checkin and checkout dates?
Old Oct 24, 2005 | 02:21 PM
Marktini's Avatar
2006 SLK55 AMG/// 2006 Porsche CaymanS 2010 135i
I remember torque as something like this:
Informally, torque can be thought of as "rotational force". The rotational equivalent of force, measured in pound-feet.
One pound-foot is equal to the twisting force produced when a one-pound force is applied to the end of a one-foot-long lever.
Old Oct 24, 2005 | 11:28 PM
Improviz's Avatar
CLS55 AMG
How stuff works .com's horsepower page (has torque info)
