Contol Arm bushings
They replaced a control arm bushing and it seemed to eliminate that sound. After 1000mi, same sound. I took the car in and it turned out the newly replaced bushing went bad. This time, they replaced the entire control arm, both front struts, bushings and did an alignment. Everything checked out okay.
Last week, I was parking my car and as I turned the wheel to the far left, I hear a metal-to-metal "clank". WTF was that? Sure enough, the original "thud" sound came back again. I brought the car back to MB - its the same bad control arm bushing. I had 3 different techs from 2 different SA teams to look at the suspension to find out if there is another issue that is putting undo stress on this particular bushing and they all said no.
So, do any other owners out there have similar issues?
BTW - They tried to tell me that my aftermarket springs could be the culprit. I told them that they could put back th OEM springs but if it happens again, then they have to put back my aftermarket springs and cover labor for both removal and re-install. They agreed, its probably not the cause
I was quoted 150, because the arm has to be removed, and the bushing installed using a press/vice. This guy is a mercedes shop, and does good, timely work, so it might be more than average. I am sure I could find some corner shop that says they can do it, but then they just figure it out along the way, as opposed to this guy that has done many, and all I will save is 50 bucks.
Another place told me that it is better to replace the entire arm, because there is a ball joint at the other end, which will have to be replaced eventually, or could be damaged while removing the arm to replace the bushing. He said he would take in trade the bushings that I already purchased, and replace both entire arms with new bushings and joints for 600.
However, I think I will let my guy change them for 150, and worry about the ball joints when it happens. The car has no rattles, clanks, squeaks. May not even need the ball joints, as the recommendation came from Tire Kingdom when I tried to get it aligned. I have a five year alignment contract that I purchased for about 250, and I suspect that TK is just trying to find excuses to do work and not make good on the alignment contract.
I have heard that the control arm bushing are known to need replacing on the C32.
Guess what? They aligned it in about 45 minutes, and claim there's nothing wrong with the suspension. (I didn't tell him the other store said taht I had to change the control arms/bushings.)
Two TK branches, two opinions.
Now, the tires are worn, but not below the wear bars. However, the front left has a slight bulge on the the inside tirewall, about the size of half a golfball, that came with the car when I purchased it. (added feature, :P ). I never had shakes or anything until recently, when the car will shimmy a little at 70, and always has a very, very slight pull to the right, even though the alignment printout is in spec.
I now notice that the outside of the front left has a little bit of belt showing on the shoulder, but not all the way around. I thinking it is just the bulge/out of balance, and two new tires will fix it all.
But also leaves the question of which came first...the shimmy or the wear?
I have looked at the newbie post for tire recommendation, but I will search again, and if not, I will start a tire thread.
If you know a good tire thread, please post.
Anyway, the bushing replacement went smoothly without damage to the ball joint, and allowed a perfect alignment. Now my car rides incredibly smooth and handles like a dream. I also got a pair of Mich PS2's in the front, and I'm sure that helps too.
The general consensus is that those bushings are short lived on our suspension.
Can you put me in contact with star cert.? I found a place for $160/side but they don't specialize in Mercedes.
I'll go search a bit further to see if I can find the service paperwork for that visit, but the amounts that you guys are getting quoted (sans the $150 steal from the Indie shop) are about the same as what I remember them billing my warranty company.
I have done mechanical work ever since I was a lttle kid following my dad around. I have even done rebuilds on an '85 Buick 4 Cyl, and an inline 6 FI Maxima. I know what is going on when I am being quoted for a job, but I would rather let someone else do it; for a modest price I don't get dirty, and I can earn at my rate working at what I do. I do computer work, and I had to let go of a customer very quickly once. I had quoted him some custom software, and his response was, "Why are you charging me so much?, You're just typing on a keyboard." That was the end of our meeting.
(end of rant...
)BTW: My mechanic has quoted me $270 for the tranny service that's going to be due at 90K miles. For that he will drain and fill the 12 quarts of MB tranny fluid that's about $14 a quart and replace the filters and seals.
He's quick, reasonably priced, and curteously answers any and all questions. That's probably why this guy has been there for a long time, and he's always got work.
(end of rant...
just did and oil change last week. i have the oil filter wrench and a skimmer. it's really simple the dirtiest part is removing the rubber gaskets and filter from the cartridge.
btw- the oil service interval reset procedure in in the manual.
i use 50% 15w50 mobil 1 (the good stuff - a SL rated oil with full additive package) and 50% 0w40 (1000 ZDDP). the 0w40 shears down to 0w30 and i'm left with ~7.5w40. ZDDP is 1100 in this mix.
From the Chevron.com site:
"Can I mix different viscosity grades of motor oils?"
"Yes. It is always advisable to not mix motor oil brands, however, different viscosity grades of the same brand motor oil are compatible. Be aware that mixing viscosity grades will turn out a product that is different in viscosity than either what was originally in the engine or what was added."
From Shell.ca:
"If you mix viscosity grades such as a 5W30 low-viscosity oil and a 10W40 higher-viscosity oil, it is reasonable to expect that the resulting product will have viscosity characteristics which are thicker than the 5W30, but thinner than the 10W40. This change does not reflect incompatibility - it's simply a re-balancing of the viscosity characteristics. In all other ways, the product should work as expected. But there's absolutely no danger about incompatibility resulting from mixing engine oils," Miller says. "We've tested all of our grades and brands, and we haven't observed any problems."
From Mobil1.com:
"For our customers to choose a viscosity grade, we recommend they follow the engine manufacturer's recommendations as indicated in their owner's manual. There is no need to mix two Mobil 1 viscosity grades when one will do; however, we see no problem mixing different SAE grades of Mobil 1 Tri-Synthetic series motor oils."
I agree that mixing oil viscosities isn't really necessary though. 5W-30 is going to have the same viscosity as 10W-30 when the oil is hot... might as well just use 5W-30 for its cold temperature "flowability". So the viscosity mixing argument is kind of pointless.
Question is on performance or any real advantages in your case?
