Why only 370 HP 5,5 liter vs. 420 HP on Audi 4,2 liter
Time to make the swap ???
Another example is Mazada Rx7 Rotary engine, it is ~1.3 litre and it delivers 250hp! And, that thing probably drinks as much fuel as the 5.5 litre.
In marketing view point, M3, S4 and C55 are very different designed cars aim for different market consumers. A BMW lover will not go and buy a Benz just because the C55 is 10-15% more hp than the M3. It is much easier for MB to make sure a Benz lover will find a Benz as fun as power and as fun as the M3.
In engine design view point, I dont know engines design well to defend for MB. However, it is still how well an engine power is translated into performance, handling, safety and fuel efficiency that matter most.
M3 is a winner on power and handling and great powerful 3 litre engine. And then, it is still not a V8
HP is the application of torque to the crank at a rate of revolution (i.e. "work")
HP = Torque * RPM / 5252
thus also
Torque = HP * 5252 / RPM
..no two ways about it ... that's how you calculate HP from torque or torque from HP. Notice how as RPM goes up, HP goes up in like kind, because it's being multiplied to the torque value.
Our 5.4L engines "shoot their load early", with torque peaking in the 3K range, and significant torque rolloff above 5500 - 6000 rpm. However, absolute torque produced by them is
That Audi engine has a +8000rpm redline. Though that engine doesn't produce much more torque then my old 4.3L AMG engine that came stock in my car before (the new 4.2L Audi engine is about 325 ft-lbs of torque), that torque stays flat well well up into the RPM stratosphere ... resulting in the high HP figure.
The fact is, the higher you can raise your redline -- while ensuring that your torque does not trailing off too rapidly, which is a function of how well you can enable the engine breathing at high rpms, minimizing rotational momentum, keep your valves operating efficiently, many many more factors -- the higher your HP rating of your engine will be.
However, With that Audi engine:
A) final rear (and front as it's AWD) differential gearing of the car =must= be very short (high numeric ratio) compared to what we run in MBs, to provide enough torque multiplication through gearing, to compensate for the "meek" torque the engine produces.
B) The driver WILL HAVE TO take the engine up to the 8K redline to get the most out of it, and compete with our Hi torque "relatively low RPM" AMG engines. If the driver of the RS4 short shift it in the 6K range, given its weight and drivetrain resistance of AWD, perfomance of the car will be on-par with say, a new C350 or SLK350.
SUPER EXCITING RIDE< BUT YOU ARE RIGHT ABOUT TORQUE< IT REALLY KICKS IN AT AROUND 6000k rpm.
Absolutely perfect expression!
I gotta credit and thank Carl (coolcarlski43) for that one... :p
