Need Advice on Adding More Power to HPS SC
I will ask Jim at McDonald's to send to me and I will post Monday. I just hope they are my files.
excuse. The ECU programming made almost no improvement after weeks of "road tuning." The problem was the blower kit from the very beginning. Also, how do you think a naturally aspirated 55 motor is going to make 600HP. It ain't gonna happen without lowering the compression ratio to the E55K 9:1 compression ratio. And to do that, you would need to change all the internal parts of the engine, which will cost a grip. Some people with modded E55K motors are having trouble making 600HP. Do a 55K motor swap or a kleeman kit.
I think you need to calm down on your Witch Hunt for power, Your car has deffinitely been compromised during this *** backwards attempt at achieving the promised +400rwhp. (I DON'T THINK MECHTECH IS TO BLAME HERE)
As said by another poster, I also HIGHLY doubt another tuner will touch your car after there aware of this abuse (200+dyno pulls on a brand new motor running to much boost AFR's all outa wack ect..) they probably wouldn't want the liability.
I think w/all said and done you should hold HPS to your earlier claim that they would buy it back from you, Start over fresh unload this car if you can....
Really sucks about your car. I don't even want to think about what damage was caused to the motor. Also, from what it sounds like, Mech-Tech seems to be just as shady as HPS. If I was a dyno shop, there's no way I would ever let a car leave my shop with a dyno that wasn't for that car.
And again, my opinion of Jesse's tuning stays the same. Before this, the only thing I had ever seen his software do was make 2 cars run about 10whp below factory (right peter?
) and fry someone else's ECU.
AMGSC I'm very sorry for everything you have gone through and dealing with all the "Melrose Place" drama. I hope HPS does the right thing and gives you everything you deserve so you can get your Kleemann system. Do you think HPS will buy your whole car back?
this sux
Lol.....correction !! After our talked last night, i could not believe the numbers !!! I was trying to figured out what wrong with your car after going back to stock pulley. One thing we both know that we both saw your car making 396 rwhp w'8 psi on the dyno. The only thing difference now was, they went back to stock pulley and Jesse did some road tuning to correct the driveability issues and then all the sudden the hp changed. My question that i want to ask you last night was, when they went back to stock pulley, do you know if they retune the car at WOT again on the dyno? They should because they went back to stock pulley and things will change. We both know that Jesse only tune the driveability over the weekend.
w/30-39 rwhp gain after buying a gen II for $9000-10k including taxes& installed
I flat out don't give a **** anymore I'm selling this paper weight and moving on......
I'am curious though how did Fast55 pull off all those kill stories I read w/his gen II...I guess we all exaggerate a little
No offense Fast55 were all in this NIGHTMARE together Last edited by Thericker; Mar 11, 2006 at 07:52 PM.
I don't know. One thing both AMGSC and I know for sure is that the car has no problem making 365 rwhp with stock pulley and air fuel ratio under 12. We both saw it on the dyno. My only guess is, something was changed by mistake after return to stock pulley that cause the power to drop so much. I don't really know, this is just a guess.
The one amgsc posted shows only 327-339 rwhp???????????that 365 # was the rw torque
They can't do it man, Game over this Maggie w/hps marriage is falling apart at the seams.
I wish it worked to but.....Guess I was right way back when you let me drive your CL55 post gen II install, and I told you "Linh don't get mad but your car doesn't feel any faster than mine"
They've tried tuning the hell out of it and came up right back where we started.
They paid Jesse $5k If he could make the power he would've done it by now
no more excuses...
QUOTE]
Yes, it does dude, to both of us. You got to realize that the set-up was not the same at the time we both saw it on the dyno. The boost is changed, you don't think that the boost have any effect on the gain? I'm trying to find out to see if they retune the car again on the dyno after the pulley is changed. I doubt it because there's NO way on their right mind return the car to AMGSC knowing the car only gain 332 rwhp. Again, this is only my guess.
I'm going to have MT install the 500 w/35k miles on it, and sell the fricken car I'll get more $$ for it than if it was just a 430 so all in all that's how I'm dealing w/it...
Besides what's the big +++ about there ECU anyway I sure don't see it here.
Sean, yes i do. What does that have anything to do with what we're talking about it right? Just keep your personal differences out out this. We all know what happen the last times and i thought that you apologized to HPS? You don't need to answer it, so let just keep it out.
QUOTE]
He pulled all could out've it w/less boost and that's all she's got plain and simple..
For me the ship has sailed on HPS as of last Friday afternoon. NO MAS MAN!
I flat out don't give a **** anymore I'm selling this paper weigh and moving on......
