Need Advice on Adding More Power to HPS SC
Do you have any suggestions on how to cool the car down? I've heard Mist but it sounds a bit crazy. Won't the moisture cause the engine components to rust?
I will definitely give Mech Tech (Jim and/or Travis) a call. I did'nt know that they even had a hand in the design either.
BTW. Did anyone have a hard time installing the Lorinser Roof Spoiler on
a C55? I ordered one from Eurotech (Neal) and the antenna hole seems to be too small. Just curious.
A dual pod should cost around ($50), I had my pod custom-match upolstered to my A pillar ($225), Autometer vac/boost ($75), Autometer fuel pressure gauge ($260), installation ($200-250). The numbers can go deeper into your pocket as you get into the higher-end gauges. Also, I've never had any issues with electronic interference on both the E430 or the Vette. I can email you a picture of my setup if you like, or Mario (E55cent) can post a picture of his...if he ever stops lagging and gets it installed!
I used the Aquamist 1s with good results in combo with upgraded cooling hardware, the only tedious issue with the 1s is calibrating the pressure switch to spray at your desired PSI, factory set is at 3PSI. I suggest you do your homework and research if your unsure with the water/methanol injection idea. I was constantly on the mustang forums, not becuz I was a big Ford fan, but those guys heavy modded their SVT Eatons; NOS, ported blower, alky injection. The Vette guys are in the same boat with their MP112s too. Also, your not limited to Aquamist; Cooling Mist, Snow Performance, Alky Control are a few vendors.
Here's a water injection forum that may interest you, Richard Lamb (inventor of Aquamist) is a member and brings his 2 cents.
http://www.waterinjection.info/phpBB2/
OK...it's late and I'm ranting!!!
Good Luck
I will definitely ask Bill K, the Engineering Director and Creater of the SC at HPS about the cooling upgrade since he is already going to install a special pulley kit that will get me another 1-2 lbs of boost in exchange for exhibiting my car at the LA Auto Show (Jan 6-15th). They will also install the K&N filters.
Bill mentioned that he "still has a few extra tricks up his sleeve" so I guess I'll ask him what they are when the show closes. I also want to get his blessing on the Headers, Downpipes and Exhausts since some of you made a good point about that. As far as ECU I will ask him exactly what they do to the stock ECU to make a replacement unnecessary.
Nobody has mentioned the traction problem. Is the LSD that much better than the stock ESP? I have experienced some slippage when I accelerate from zero. Would ligher, wider, bigger rims and softer tires help?
You posted a dyno sheet with A/F it clearly that its is mostly under 12:1. The HPS GEN II using a piggy computer to modify for A/F and also reduce timing. If you get a computer you will mostly ruin your A/F and possibly damage your motor. Tuning for NA motor and blown motor is completely different. Most ECU that do exist for the C55 is for NAd are only applications.
Now if you could get a completely reprogrammed ECU that had different target A/F in open loop, and had it retard your timing, and remove your speed limitor and etc that would be great.
IF you make any changes you can always have a reputed shop modify the piggy box to insure properly operation.
Now we talked about more boost and etc and this where effective compression ratio is used. The formula is ((boost pressure/14.7)+1)*Static Compression Ratio.
For say running 7.5 PSI
((7.5/14.7)+1)*11=16.6:1 Effective compression ratio
Now for reference its not uncommon to see say 17PSI on a 8.5:1 compression ratio car
((17/14.7)+1)*8.5=18.3 effective
Personally I run 20PSI on 93 octane in a turbo charged applications. And 25PSI with water injection and etc. Which ends up witha very aggressive effective compression ratio. Not something I would recommend for a supercharged application atleast not with some metering of air intake temps, Cylinder head temps, and etc.
For reference I would be aggresive and run 10PSI which would be ((10/14.7)+1)*11=18.47 pretty much the same as a boosted car.
Now I don't recommend anything much higher than that. Domed pistons used on NA applications versus dished used have different heat properties.
Lastly a cam is the heart of engine performance anyone who attempts to tell you different is mistaken. Now the question becomes is there a properly designed cam for a supercharged application? I am not sure but if you are in the business of performance certain cams produce different results. Engine dyno simulators used by people in the business will give them a baseline as to what to use. Cams are of the biggest secrets in performance and in theory could make an engine. So if you want to try a cams go for it tho I could not recommend you which ones to try as I have no specs on any them.
Does anyone have an updated availability schedule? Where can I place my order? Through EVOSPORT? or some other dealer or directly with Quaife? What does the dealer offer besides a mark-up? Will they provide additional warranties or installation assistance?
i have ordered mine direct from quaife but
so far i have had no word on a fixed price or completion date so i will contact them again early next week to try and get an update on progress
Based on what I've read and after speaking to some engineers this unit MP112 is radically different from the old roots blowers. Please go to the Eaton website and read about this unit.
The claims about the inefficiency of roots blower should not apply to the MP112 with all of it's changes. You can see from my dynos that I easily gained 147bhp with a green engine WITHOUT ANY other upgrades. This car was dynoed on a warm day in Escondido, CA with no super-cooling fans or high octane gas.
When I read about overheating concerns with the Eaton unit I called Adam at HPS and he reminded me to look at the HPS Picture Gallery where it cleary shows that not only does the SC have a ultra heavy duty intercooler but ALSO a seperate HEAT EXCHANGER for duel cooling effects. The fans are also reprogrammed to kick on as a third backup although rarely if ever needed. If the temperature still creeps up after the upgrade then I will inquire with HPS about mist sprays and such.
By the time I get the car back from HPS after the show. They will add another pulley kit, larger fuel injectors, K&N filters,reprogrammed ECU and other "proprietary engine mods" that should result in a difference between "Night and Day" according to their chief engineer and his tuner experts. In fact there is another CLK 55 of theirs that had these similar things done and is much much more powerful than my car according to Bill. He also assured me that these upgrades are absolutely safe and there are no risks at all to my engine.
I am expecting/hoping for a minimum of another 50bhp :v which is reasonable considering that the car only had 600 miles on when I first dyno'd it. I will have all these upgrades completed by the end of January and hope to post my new dyno's from Mechtech a week later along with videos of Bill, Adam, Mechtech's owner Jim and I test-driving it after the dyno. After I install a set of Quaife LSD's I will then take it to track and post some times (0-60, quarter mile, etc...).
I am now considering the following in numerical order...
1) Smaller Pulleys.
2) Headers
3) K&N or Green Filters
4) Replace Exhaust System and remove resonator
5) ECU reprogram
6) LSD
7) Cams and Downpipes.
Does this make sense?
He did not add anything else since I called him Friday and asked. He is also waiting on the results of my HPS pulley kit, larger injector and ECU upgrade which add another 2 lbs if boost (Currently running 5lbs yielding +147 HP) We both want to add the headers and possibly camshafts. I am probably going with additional cooling even though Brandon nor HPS felt it was necessary.They fine with the intercooler and heat exchanger but have modified the fan to turn on at a lower temperature setting (10 F earlier). I am paying him a visit since he lives only 20 miles away from me this week.
Here are his dynos.
I'm really interested in your new kit with the extra 2lbs of boost.
Take care
Now you need to get your car to the track and see what it will run. I believe I hold the title with an 11.997 @ 117 on street tires.
I'm hitting the track again this friday with my new Mickey Thompson drag radials... guessing I'll probably run an 11.6... we'll see.
I don't know if you've ever seen the inside of a c55 resonator, but it is straight thru. Replacing it with a straight pipe shouldn't make a single shred of hp.
You never did answer my question - how much boost is the HPS s/c running?
He actually wanted me to see what he did and offered to take me to the muffler shop to get it done. Can you do me favor and post your latest dynos? I'd like to see your A/F Ratio compared to his.
