Need Advice on Adding More Power to HPS SC
#1051
Super Moderator Alumni
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Do all of us a favor; sell the car and buy him a nice Mini or some other 4 cylinder car.
#1052
SPONSOR
Wow...
#1053
1 Post
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
#1054
No worries. I installed a self-ejecting seat in case that happens.
Seriously I'm done with replica wheels. They may look identical to the real thing but I did'nt realize that they want to escape from their owner like a wild stallion. I've got Original 3-piece rims this time.
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
#1055
SPONSOR
#1056
#1057
1 Post
Should I go with Powerchip or SpeedtuningUSA?
After 14 months of futile attempts to hit 400rwp. I've decided to go to Evosport and get the Powerchip installed for $1,490. Did they overcharge me?
I gave up on SpeedInnovations and I changed my mind on going with another independent tuner in Fremont since I don't want to send my ECU to a guy I never met before who does not have his own dyno.
I have an appointment this Wednesday to get dyno'd and data logged so it can be sent to Powerchip.
Should I keep my appointment or does anybody recommend somebody else that is ESTABLISHED (Not a freelance/independent tuner). Can anybody make a strong case for Kleemann, Renntech, Brabus, Carlsson, GIAC, SpeedtuningUSA OR ANY other MB chip tuning specialists?
Has SpeedtuningUSA solved the problems that caused quite a few negative experiences?
#1058
#1059
AMG 55, 335i, Mini Cooper S
Have you spoke with Powerchip? I spoke with them three times, and I got the impression that they know very little about MB tuning, and were not able to provide anything beyond the most basic services. I paid $990, and now feel that that is overpriced since Kleeman and Renntech offer their ECU services for $1000, and that includes competent support and future tunes. I realize that neither Kleeman nor Renntech would touch your car with a 100 ft pole (with good reason), so I guess Powerchip is your only option.
Just my thoughts and 2cents
Mario
#1060
1 Post
Dyno before Powerchip Tuning
Let's see if Powerchip can take this over 400rwhp. The first run is with the Coolmist Stage 2 off. This is with 91 Octane Costco Gas and stock ECU. As you can see my Air/Fuel dips below 10 immediately at part throttle!
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
#1061
S600TT, R350
#1062
should have gone RENNtech or Kleemann to begin with...Since money is no object!?!?!?!?
both Josh and I have over 400rwhp with 0 problems! (well josh sold his but still)
BennyZ / BennyZ06
BennyZ / BennyZ06
#1063
1 Post
![action](https://mbworld.org/forums/images/smilies/action1.gif)
I called Cory@Kleemann and the Renntech guy at Meridian and they both told me that they cannot tune a competitors supercharger. Brabus in Newport Beach told me the same. However, Oliver at SpeedtuningUSA will custom tune my car for $350 + $200 until he gets it right. I am sending him my data logs tonight. I'm starting to have some doubts about Powerchip based on the last two postings from Mario and jgsx. I may cancel my appointment if I don't get some positive feedbacks here in a day or two. Of course, I'm also interested in getting the Evosport Underdrive pulley kit, phenolic spacers and Quaife for a C55 so that might sway me to go with Powerchip. I'm still trying to figure out who makes the best yet reasonably priced header and exhaust system.
I think Powerchip can retune my chip for $50 if I decide to go with the Kleemann or Renntech SC later. Am I correct?
#1064
I thought you sold yours as well after getting the Z06. Can't wait to see you mod that thing!!
#1065
1 Post
That advice is at least worth 55cents j/k![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
Btw...That Coolmist is a blast! I have a few 5 gallon drums of ethanol in my garage but the car gulps it like gatorade! Is there any damage to the pump if I turn it off during these cold days lately? Did you ever turn yours off?
#1066
I kept the C and got the Z. hehe
If I were you, just start from scratch! take everything off the car, I mean everything. And start fresh!
I would even sell the C - take the hit, get a new C and start over.
Just my thoughts.
BennyZ
Just my thoughts.
BennyZ
#1067
You have tried to make this car work for you but at this point cut your losses and just go back to the way it came! You wont regret that. Just go with one tuner next time and leave it at that.
#1068
1 Post
Dyno Data Sheet from JBA
For you tuners out there. What do you make of this data? If you can help me please reply....
#1069
1 Post
Dyno Data Sheet from JBA with Boost numbers
As you can see the blower is making the 7 lbs of boost. What else could be wrong?
#1070
S600TT, R350
If it is a bad, restrictive design than instead of pushing air inside the engine, it allows it to stack up and create boost.
#1071
V12-Biturbo
That's funny I've seen the most heavily modded C32's here on the forums, making no more than 355 rwhp and that's w/Dyna Pak dyno, where they remove your rear wheels, there's no rolllers, or tires/wheels to loose power thru, ie..5-10% lower results on a real Dyno Jet... meaning the C32 modded rwhp is more like 300-325rwhp in reality
#1072
1 Post
If your answer is true, which I've heard from some others, then there is nothing more I can do to this kit.
#1073
Mario
#1074
1 Post
Last Independent Chart - before she goes under the knife
This chart shows that MechTech's dyno was a bit optimistic...
#1075
No it doesn't. That's a dyno dynamics dyno. If anything, this dynamics dyno is optimistic, or the dyno jet at Mechtech is conservative.
Man, when are you going to LISTEN to anyone in this forum.
YOUR PROJECT WAS A FAILURE! SUCK UP YOUR LOSSES AND MOVE ON! STOP DUMPING MONEY INTO THAT BLACK HOLE!
![BeatDeatHorse](https://mbworld.org/forums/images/smilies/beatdeadhorse5.gif)
