C55 Stock RIM replacement
I am deciding to replace just one rear rim , and will buy it from Benz dealer to make sure it is identical to the other rear one.
The question is, would the rear wheels becoming 'unbalanced' if one of them is newer?
I know it may sound stupid , just want to make sure before I order it.
Any one replaced one RIM ? , and how much was that costed?
cnt
You should instead get a set of Flik Artic's or something, relatively cheap and you don't have to worry about getting them scratched.
The only occasion that C55 rims will be scratched is when I am out of the exit parking lot where the pathway is 'S' shape and the sides of the pathway are very rough. I know I should complain to the building mgmt.
It always rubs the left rear rim.
I did swap the rear rims so that the nice one is on the left facing the pedestrains ; and fck it, the rear left was scratched again.
Actually I should have replaced both rear rims but look at the cost of two rims, I am thinking why pay the money for the same rims and not going for 19" for a change?
why do u want to get it from the dealer?
u can prabobly find some used "new" wheels for a lot cheaper and insted replace both.
The thing is , C55 is the first Benz receives this AMG style rims. I saw many W210, W211 , W203 were also getting these AMG rims in those AMG sports packages. But I ain't sure which non AMG are/can use rear 18" 245 9.5 as they are mostly 17" I guess....So I have little hope actually.
the slk 55 has the same wheels also the clk55 newer models have those
We have too little number of SLK/CLK AMG, more E55, C55 is most rare; but many non-AMG Benz gets the AMG sports packages; so basically their cars are a 'AMG' except the engine and the seatings
Okay, in fact , I have been observing I am building up a sense of an alert whenever I pass through the entrance; so I guess it only happens in the same place again if I were really driving in bad mood that day
I will probably replace both rears ( even one of them is not as bad ); so I will keep one in my store room until one day, touch wood, a rear is scratched again and if worse than the one in the store room, I will have a 'spare'.
Yes, 19" is very tempting; I would probably prepare a big spend including to replace the C55 grill to the 2006 CLK 3-slates star grill :p !
