steering wheel install how to?
Old Feb 13, 2006 | 01:48 PM
pointman's Avatar
a car that can't do the throttle reset.
i am going to be installing a new steering wheel on my 04 c32. is there anything i need to be careful of?? any tips appreciated. thanks.
Old Feb 13, 2006 | 02:00 PM
Bif powell's Avatar
2002 c32
I would be careful of the explosive charge in there. I'm going to have the dealership do mine.
Old Feb 13, 2006 | 02:19 PM
razorfish228's Avatar
BLACK 05 C230SS
Yeah, you need to defuse the airbag. There is a fuse which you must remove in order for you to even unscrew the airbag.
I think your better off asking a mechanic to do it for you. It doesn't have to be MB dealer. The airbag cost alot if you explode it.
Old Feb 13, 2006 | 02:39 PM
pointman's Avatar
are you serious?? I thought as long as the key is out of the ignition that everything was okay.
Old Feb 13, 2006 | 02:52 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
I've been able to remove the airbag from the car w/o unplugging the battery or fuse. Make sure the key is out of the ignition so the SRS light doesnt set off.
Use a torx socket to remove the 2 bolts for the airbag. Once off there is one more bolt that holds the steering wheel on the splines.
Old Feb 13, 2006 | 02:56 PM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Best writeup on the net by Gregs210 see below
https://mbworld.org/forums/showthrea...light=steering
Old Feb 13, 2006 | 03:30 PM
Bif powell's Avatar
2002 c32
Side question: how do you find out your radio codes (and what else do you need to know) for the reset procedure?
Old Feb 13, 2006 | 03:50 PM
pointman's Avatar
awesome, thanks!
Old Feb 13, 2006 | 03:51 PM
pointman's Avatar
nice. thanks for the info.
Old Feb 13, 2006 | 03:53 PM
pointman's Avatar
is the radio code really necessary? didnt need it in my ml.
Old Feb 13, 2006 | 04:22 PM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
No need to pull fuses. Just be sure the key is out.
Old Feb 13, 2006 | 07:23 PM
Bif powell's Avatar
2002 c32
Just going by the write-up.
Old Feb 13, 2006 | 08:10 PM
pointman's Avatar
got it. thanks. and radio code is not necessary i take it?
Old Feb 13, 2006 | 08:25 PM
Thericker's Avatar
V12-Biturbo
I'm surprised there isn't more to it? I just had my 01 S430 @ the dealership to swap in the 2006 AMG wheel I bought off ebay.
I have a few friends down there and they only charged me $160.00 to do the job, It seemed much more labor intensive resetiing codes and test driving after to make sure it was alligned properly(took about 1 1/2 hrs)...Good luck to you I tried going to another dealer while I was in LA and they refused to touch it unless I bought the wheel thru them gave me some malarcky about liability
Old Feb 15, 2006 | 10:04 AM
smgC32's Avatar
Talking
Old Feb 15, 2006 | 11:27 AM
Bif powell's Avatar
2002 c32
I dig that, but I always wonder then how you access the menus. Sans COMAND I don't know how you would get to those menus/options.
Old Feb 15, 2006 | 11:33 AM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
Not on the C class. What wheel are you getting?
Originally Posted by smgC32
I personally don't understand why you would eliminate the airbag.
Old Feb 15, 2006 | 02:38 PM
Dead Ringer's Avatar
02 C32R
yeah, how do you change the the options now which you wold do form the steering wheel mounted controls??
Old Feb 15, 2006 | 02:45 PM
pointman's Avatar
he's got to lose them.
pointman's Avatar
carbon fiber. a member on the site is selling his.
