Question about 19" rims??
Old Feb 25, 2006 | 11:10 PM
ccw998's Avatar
Hi,
I am looking for a set of 19" rims. I am wondering that what is the suitable offset for the front and rear of 19"?
Please give me some information.
Thanks!!
Old Feb 25, 2006 | 11:24 PM
jtc55's Avatar
08 E63
for what vehicle?
Old Feb 26, 2006 | 01:28 AM
SteveL1's Avatar
'16 SL550, '18 Porsche Macan GTS
Before the moderators get here and scream at you for not using the search function.................most wheels for the C class(I assume that's what you are looking for?) are 35mm or there abouts. It will somewhat depend on which brakes you have as to whether you will need spacers of not. The '05 & '06 Sport Sedans have slightly larger calipers that the others. That's why we ask what car you are specifically looking for info on. Good luck, and promise to use the search function first next time.
Old Feb 26, 2006 | 03:48 AM
ccw998's Avatar
Originally Posted by jtc55
for what vehicle?
For 2003 C32
Old Feb 26, 2006 | 04:09 AM
D2-AUTOSPORT's Avatar
Former Vendor of MBWorld
VIPER
Originally Posted by ccw998
Hi,
Thanks!!
Got your email and replied
Old Feb 26, 2006 | 01:09 PM
Blake P's Avatar
'09 A4 S Line
28 - 30 offset up front will ensure that you clear the front calipers without spacers and if you decide to add coilovers, you are more likely to clear the perch and/or spring without rubbing issues. The downside is that the wheel will be pushed out more, so if you are running 8.5" width or higher, you may rub on the fender and need to get it rolled and/or shaved.
Old Feb 26, 2006 | 09:10 PM
AWDman's Avatar
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
backspacing may be a bigger problem than offset. the spokes of the wheel have to sweep away from center and then come back in to meet outer rim- in order to clear the big calipers. that's why every 30 et rim will not work.
if you get 8.5 inch fronts then et of 30 is perfect. rear et should be 35 or a bit higher is running 9.5 inch wide.
Old Feb 27, 2006 | 03:16 PM
VIPER
Yeah the newer cars (not only the w203, but some Acura's, Lexus, V-spec Cadillac, etc) are almost forcing people into custom wheels, as many "off the shelf" wheels will not clear without spacers and such.
Old Feb 27, 2006 | 03:41 PM
AWDman's Avatar
yep i've been struggling with this for my mitsu 3000 gt vr4s since 2000 when i bought my 1st one. those are worse d/t need for 45-48mm et and again big calipers in front. very few aftermarket wheels would fit.
Old Feb 27, 2006 | 04:46 PM
VIPER
Correct, the good thing is there are companies like WORK that have reasonably priced custom made multipiece wheels (I know everyone doesnt want to spend 4k wheels alone! lol)
