throttle booster, highly recommand!
You pop the little cap off in the lower portion of the throttle base and take out the 10mm bolt underneath it. You pull out the entire throttle and unplug it. You plug the sprint booster inline, and then put it back together.
The install took less than ten minutes.
The car FINALLY feels right. The car should have come from the factory this way. I HIGHLY recommend the booster.
I fitted one of these on my C32 3 months ago here in Australia, and the only reaction I got was that I was full of BS about it all! see:
https://mbworld.org/forums/showpost....9&postcount=39
and:
https://mbworld.org/forums/showthrea...sprint+booster
Oh well, maybe finally people will believe that this thing does work!
Joe
I finally installed my Sprint Booster. I've been so happy with the thing that I just wrote a long response to this thread, detailing how awesome it is and encouraging a W203 forum group buy. However, using Firefox I accidentally closed the tab i had composed my response in before sending, and lost 10 minutes typing.
GRR! Give me some time to recover my wits and I'll try again later...
1. Remove the lower nut cap.
2. Remove the 10mm nut.
3. Remove the washer, a magnet helps.
4. Remove the pedal, lift the bottom pulling out and pull it out of the upper bracket.
5. Unplug the tps cable from the sensor.
6. Plug the tps cable into the Sprint Booster.
7. Plug the Sprint Booster cable into the tps sensor.
8. Reinstall the pedal assembly.
9. Have fun
from the ebay.ca site, they have some installation images - here they are for anyone wondering.....
First off, I just want to chime in again in support of this mod. I do not have anything to do with the manufacturer or sellers of the Sprint Booster, and I don't get anything from talking them up - it's just a fun, cheap mod that should be tops on everyone's buy list here, no kidding. There is no snake-oil salesman lurking about here
Second, the install. It is exactly as jgsx said, and like the photos boohooramblers posted. Took all of 10 minutes, and I saw immediate improvement. The car really does behave much more like it has a mechanical linkage throttle now, though if you drive in many varied traffic types you will still be able to detect some non-linearity. It feels as if they wired a logarithmic-scale potentiometer in series between the pedal and ECU, such that the phase of the stock dampening effect and the phase of the fix cancel each other out. The result is a decidedly more linear feel. You could theoretically get similar effects by modifying how you use your gas pedal normally - but it would be bizzarre because you would have to stab at the throttle fast and to exactly the appropriate percentage of travel every time. Good luck developing that kind of precise leg and foot muscle control!
My favorite thing about this mod: the "D" (auto) mode of the transmission is finally usable! After a long tiring day at work, I can now leave the car in auto and use the gas pedal alone to call up throttle and downshifts exactly appropriate for the amount of pedal travel, instead of (1) guessing, (2) waiting, and/or (3) just using manual mode to ensure that it downshifted the right number of gears. How many times have you been cruising along in traffic at say 45-55 MPH, and needed a single downshift + some throttle to get into a briefly-open hole in traffic? Before, if your car was in "D", you would press the pedal and get almost nothing. Then, you'd press harder and even if you were smooth you were gambling that the car would not just go two gears down and give you more than you asked for. I'm not some kid in a Civic with a giant wing on the back
- I want smoothness AND responsiveness, without getting all out of shape and embarrassing myself and/or scaring other motorists. The only reliable solution before was to call up a downshift manually via +/- mode, then press the gas at just the right moment to accellerate smoothly, then upshift to "D" again when the traffic move was complete. With the Sprint Booster installed, I just press the gas about as much as I THINK I should to go a little faster, and presto! The thing does as I ask instead of "Oh, you want to go faster? Umm.... how about NOW - ZOOOM!". Also, I don't get caught in auto mode with my pants down by quick cars who want to show me something. Nail it a little, nail it a lot - you get whatever you ask for.Oh - and yeah, you can chirp the tires in 1st and second if you like
Finally, I deliberately did not perform the throttle/trans ECU reset trick when I installed the Sprint Booster. I want to know if it will provide most/all of the reset benefits, without requiring resets all of the time. I had been in the habit of doing resets almost daily before. So far, it is working great, and I'll wait for a while before trying a reset to see if it is good enough alone, or if the tranny will "learn it's way around it". I have a feeling it will be fine, because what the transmission is now learning is throttle inputs that more closely resemble those I actually desire! I also want to see if it becomes too touchy after a reset now. I'll follow up later as I learn more.
This is the best thing you can do to your car but unfortunately you have to take the word of other drivers, so if the thought of spending about $300.00 bothers you more than accelerator lag forget about it but for me its the best $300.00 I have spent. I have no reason to plug the device as I get nothing out of it other than my car is now very responsive and more fun to drive.
It sounds fantastic!
Thanks Ernster
http://www.crossfireforum.org/forum/...=11277&page=19
